Carpet replacement
Old Feb 5, 2018 | 03:36 PM
bull jr's Avatar
bull jr
Carpet replacement
Hello All- Plan on replacing my existing carpet with some new molded carpet from LMC. Currently I've got carpet also on the back wall behind the seat up to the rear window. It was like that when I bought it. I pulled back some of the carpet and the installer definitely didn't skimp on the glue. Does the existing glue need to come off or can I just spray more on there during installation? If I have to remove, any idea how to get it off without damaging the paint? I've read some that the glue can be really tough to remove. I also bought new bucket seats from shop4seats.com and will post some pics of the install when I get them in and completed. Thanks in Advance!
Old Feb 5, 2018 | 05:24 PM
79time's Avatar
79time
4wd Low
Depending upon the type of glue, a heat gun may work.
Old Feb 5, 2018 | 05:42 PM
Tractor2n's Avatar
Tractor2n
Pictures
would you send me pictures after install, I may not know how to get them on this site.
spicerrb@Hotmail.com Thanks/Robert
Old Feb 5, 2018 | 05:45 PM
Tractor2n's Avatar
Tractor2n
Pictures
Looking forward to seeing the pictures. Thanks
Old Feb 5, 2018 | 06:13 PM
HIO Silver's Avatar
HIO Silver
Goo-Gone or a can of 3M adhesive remover. Soak a rag and let it set for a long while. When gooey, remove by scraping with something like a credit card.. remove any left with a green scrubby.
Repeat.
Old Feb 6, 2018 | 03:17 PM
bull jr's Avatar
bull jr
Thanks for the reply's. Does the glue actually have to be removed or can I just spray new glue to install the carpet?
Old Feb 6, 2018 | 04:48 PM
JRT812's Avatar
JRT812
I would think it needs to be removed.
Old Feb 8, 2018 | 02:56 AM
burnthelight88's Avatar
burnthelight88
Are you using any sort of insulation or backer for the carpet? Just curious, plan to replace mine in the spring, but not going the LMC route...
Old Feb 8, 2018 | 06:01 AM
rob8210's Avatar
rob8210
When I got my 1979 F250 4x4 12 years ago the po had carpet up the back wall of the cab. When I tore it out I found that the rear window leaked a bit , the carpet held the water and the cab had started to rot out.
Old Feb 8, 2018 | 08:23 AM
bull jr's Avatar
bull jr
initially I hadn't planned on any type of insulation or backing, but after reading some more on here I am considering it. Seems pretty simple to put in. Not so interested in the heat portion, since there's no AC to begin with but it might help the noise a little. My mufflers dump right behind the cab.
Rob8210- I sure hope that's not the case with mine when I pull it out!
Old Feb 8, 2018 | 08:37 PM
burnthelight88
Check out stock interiors on the internets, it came highly recommended in another thread here, has a ton of color choices... Just if you haven't made up your mind yet.
afinepoint
Garage & Workshop
29
Aug 18, 2018 08:40 AM
Dawnie Shinn
Feb 27, 2018 02:17 PM
dx3
Aug 20, 2017 11:39 AM
frisbeeguy
2009 - 2014 F150
May 10, 2012 01:17 PM
packman
Oct 20, 2004 06:30 AM
