If the oil filter drain valve is not depressed, it does not close. So, much of the oil that is intended to be pumped to the engine goes back to the oil pan. Therefore it results in less lubrication flow, in addition to minimal filtering. The oil that does get pumped forward will get hotter than normal because the flow is reduced. You won't ever see it on the EOT gauge.
Basically it results in engine damage from a lack of lubrication. Sounds like it might be coming from the turbo or HPOP to me.
My assumption is that this combination of cap and filter didn't "just happen". Also, if the turbo was just reconditioned, that work probably did not include bearing or VGT solenoid replacement.
Thank You. Sounds like Calvinbabb needs to have a (get your **** together) chat with his local Ford Dealer! Or somebody from a Ford dealer that will sell him the right parts.
Not my dealer anymore. once the police showed up i was told to never come bad again. No problem, sold me the wrong ***** and knew it.
i did find the problem. a crack in the bellows so going to replace with stainless up pipe with the egr up pipe none drilled and while i have it apart...... again.....going to change the exhaust out the 5". looks like it will fit but tight.
You might find you will have slightly more boost when you get rid of that leak.
When you say 5", are you talking the down pipe off the turbo?
If so I would say stay away from that idea. You will likely run into issues with clearance and rattles, but the bigger factor is it will actually do more harm than good since you won't be making the back pressure it was designed for at 3"
Some guys will run a 4" down pipe. The kids truck has a 4", but only because it came with it.
Was wandering about that as it does have a exhaust pressure sensor was wandering if it would effect it.
