Bad connection? Bad sensor? Or something else?
I started it, and wiggled the wires with it running, trying to get it to act up, but it would not. I also cannot replicate it while driving, it does it randomly, with no noticeable pattern. I have a fuel pressure gauge, and it reads 60-65 psi at all times, so not a fuel issue. I have it hooked up after the filter, so it is not the filter. I did still pull the filter out, and it is a healthy color, and not contaminated with oil. The oil level is good, and was last changed about 2,000 miles ago, using rotella 15w40 as always. I changed the ICP with a spare, and it did not help. I also unplugged the ICP while running, and it stayed the same, so I am pretty sure the ICP is fine. I have two codes, both are for low glow plug voltage, one code for each bank; however, those codes have been on for many months. I tried to find the problem, spent many hours with a multimeter, and many more hours online trying to figure it out, I decided to leave it, because they function as they should, as far as I can tell. There is another code, for low ICP voltage, but it only came on after I switched them (I switched them back, it is still on) and I tried to clear it, but it is still on.
I have spent about an hour a day reading about this, since it started to happen. I decided it is finally time to ask the experts!!
I think AE would help diagnose the issue, and even if it does not, I will have it if I ever need it in the future. What is the difference with this cheap one here, and a $350 unit?
https://www.ebay.com/itm/AutoEnginui...4AAMXQVT9TCkKI
Thanks in advance for the help!
About the only thing I can contribute at this point is that I don't think it is glow plugs. They will only cause problems when cold.
And maybe look at Torque Pro and an ODB-II bluetooth reader as an alternative to the AE tool.
IPR Tinnerman Nut
UVCH Connections
IPR
IDM
Have you recorded and cleared the DTC's? Low Voltage Injector in both banks could be an indication of the UVCH / IDM?
Unfortunately, you will have to wait until it presents the issue again to determine what DTC's are issued.
I looked into forscan, it almost seemed like it only works on android? I checked the app store on my Iphone, and there is "FORScan Lite- for Ford, Mazda" is that the right one? I am going to get a bluetooth adapter if it will tell me all of the numbers the engine is reading while running.
Walleye, you use that with forscan on an iphone? If so I am going to order it. I bought a torque pro a couple years ago but couldn't figure it out so I gave it to a buddy, I dont want that to happen again.
I would opt for FORscan - I have it on all of my laptops and my Android phone. AE is useful if you have some non-Ford/Mazda vehicles you want to connect to, but the new version is a pain in the butt to connect to any vehicle. You can't save a configuration you make for your vehicle, so each time is like the first time.
