Step 1 on a new Project
Dennis Carpenter Dennis Carpenter Ford Car, F-100 Pickup Truck, 8N, 9N Tractor and Cushman Scooter Restoration Parts
Or if you want made in USA, but I have no clue what the shipping on these would be Flashback F100's - USA Made Steel Made Repair Panels On This page will be only USA Made Repair Panels,, not like others that carry those Black Tawain cheap repair panels, Here is how I feel on ste
I don't know how much shipping is for LMC, but they are 'taiwan' steel replacements. The cab corners I sourced needed a bit of persuasion to fit but they welded up fine.
One thing on this as well, are you sure you just need floor pans? My rust holes in the floor pans came from issues with the cab support braces and cab mounts. Make sure your needs aren't bigger than what you're seeing on the surface. If you can get US pressed steel, I'd go with those above LMC. Otherwise, I had decent luck with their stuff so far.
I have never paid for a set of floor pans. $20 worth of 19 gauge sheet metal and my $99 Harbor Freight bead roller and make you own. I've even went cheaper and salvaged flat sheet metal from old 70s car hoods. They don't have to be exact like a body panel, nobody ia ever going to see them. A previous owner on my 69 just used old road signs, I never did see a good reason to change them and you had to crawl under the truck to know. Just my 2 cents
ehughes8
09-07-2012 04:22 PM
crazed87bronco
17
11-08-2010 10:31 AM
ducksbucksnbulls
01-09-2002 11:19 AM
