Another heater question.
Old Jan 30, 2018 | 05:53 PM
roadrash63's Avatar
roadrash63
Hi I would like to know where the heater draws air from in the hot setting. 1985 F250 no AC
New new thermostat 195 new heater core.
New fan motor.
I cleaned the air box out and everything I could which was considerable do to mice.... With a Shop-Vac.
Low flow and temp is lower that i think is correct...
TIA
Old Jan 30, 2018 | 06:39 PM
Franklin2's Avatar
Franklin2
It gets the air from the plenum at the windshield wiper area. Through the slotted grille between the hood and the windshield.
Old Jan 30, 2018 | 08:06 PM
cadunkle's Avatar
cadunkle
There is significant voltage drop to the blower motor through the factory wiring. Clean your switch and resistor, add a relay for the hot side along with upsized wiring. It will push more air once you fix the voltage drop.
Old Jan 30, 2018 | 09:27 PM
Tedster9's Avatar
Tedster9
Maybe you know this already, check that both inlet and outlet hoses to heater core are HOT. If not, there is a restriction, most likely in heater core. Sediment rust or scale.
Old Jan 30, 2018 | 10:00 PM
ctubutis's Avatar
ctubutis
Old Jan 31, 2018 | 05:19 AM
roadrash63's Avatar
roadrash63
Thanks
Thanks guys I will check it out I cleaned the plenum area with the Shop-Vac previously I have a new resistor also will check voltage
Old Jan 31, 2018 | 05:26 AM
roadrash63's Avatar
roadrash63
Heater
Hey I was just wondering if there is a mod or something . where you can reheat already warm cabin air instead of bringing in cold air and heating it cuz it's 13 here in Pennsylvania...
Old Jan 31, 2018 | 05:55 AM
Franklin2's Avatar
Franklin2
If you do have a factory non-A/C truck it would have to be a severe modification, more than likely cutting another hole in the firewall. If you have a factory A/C truck, just the A/C is disconnected or not working, you could activate the actuator over near the pass side hood hinge to make it pull inside air.
I can assure you, even with pulling outside 13 degree air, and even with the factory voltage drop, the heater should still give very good heat when it's stock and everything is working. We had a guy on here the other day that was struggling with his truck, and he found the temp blend door was not fully closing.
Old Jan 31, 2018 | 07:10 AM
roadrash63's Avatar
roadrash63
Ok ty,
my blend door is wired to the hot position
On box in engine compartment !
Old Jan 31, 2018 | 10:43 PM
kr98664's Avatar
kr98664
Wouldn't you expect to see the heater outlet hose cooler than the inlet? That would indicate normal heat transfer into the cabin. I've never measured the temperature drop across the heater core, but on a radiator, you can expect to see the outlet hose about 30 degrees cooler than the inlet. I'd suspect a heater core to be similar, but don't really know.
Could the exterior fins on the heater core be plugged with debris? That would both limit the airflow and the heat transfer, since that crud can act as an insulator.
Try this quick test: With the engine off, turn the key to ON so the fan will run. Don't start the engine, so you can better listen to the fan speed. Set the fan on high, temp selector to full hot. If the blend door (temperature selector) travels properly, all air will be routed through the heater core. Next move the temperature selector to full cold. All air will now bypass the heater core. If the fins are plugged with debris, airflow will increase with full cold selected.
Old Feb 1, 2018 | 07:13 AM
jackietreehorn's Avatar
jackietreehorn
You wouldn't believe the amount of crap I pulled out of my HVAC system. I would check every part of it is clean and un-obstructed.
Old Feb 2, 2018 | 02:34 PM
roadrash63's Avatar
roadrash63
Burped it
FyF
I burp the I burp the cooling system like 5 times and much better now I can actually feel some heat on my feet air flow still seems a little low.
roadrash63
23
Dec 16, 2016 12:07 PM
mccurdymark
Nov 7, 2007 10:05 AM
jimlj
Oct 13, 2007 07:04 PM
bmazingo
Feb 20, 2006 06:06 PM
fixnmyf150
Nov 7, 2004 01:36 PM
