Heater temp???
Old Nov 5, 2004 | 11:47 AM
fixnmyf150's Avatar
fixnmyf150
Heater temp???
Good morning all!!! Its cold out there!!!
I have a 1986 f150 4x4 302 fuel inj.
This summer I changed the thermastat (I believe that the new one was a 180 degreer).
My heater just doesnt get quite hot just a little bit of warm air but not untill I am on the road a while. Should I have installed the 195 degreer.
Also the defroster; shouldnt it blow out warm air as well. Sounds as though the air conditioner kixs on and off. (does the mix selection do floor and defrost or ???).
I did flush out the core and it was quite dirty.
Any help will be warmly appreciated.
Old Nov 5, 2004 | 02:22 PM
big hoss 29's Avatar
big hoss 29
Sounds like your heater core is just about to go. If you flushed it out, it should have helped. A new heater core is in your future my friend.
Keep the 180 thermostat because the temp range is just fine. As for the defrost, me thinks it's normal for the A/C clutch to come on. I've heard the same thing on my Dad's F-150. But I would replace the heater core for sure.
Old Nov 5, 2004 | 03:17 PM
fixnmyf150's Avatar
fixnmyf150
Sounds goog to me.
How do I know if it is a standard or high out put heater.
I do have 3 or 4 selections low, med, high for the fan???
Old Nov 5, 2004 | 05:03 PM
Lee Lichterman's Avatar
Lee Lichterman
Air conditioning compressor should kick on in defrost mode IF the temperature is above freezing (32F 0C). THis is done to dry out the air being blown on teh windshield.
Agree on heater core though there is a slight chance your valve isn't opening when you slide the temp selector over. Watch under the hood on the heater hose where the little valve is and have someone move it.
Changing a heater core is quick and easy. I just did one not too long ago for a leak problem and I think I was done in under an hour including breaks. -gggg-.
If you have air like it sounds you do, it will come out from the inside. Just pull the glove box, a couple screws ( 5/16 I think), disconnect the hoses and it's out. I wrote a full how to a few weeks ago and it should come up on a search.
Good Luck,
Lee
Old Nov 7, 2004 | 01:36 PM
fixnmyf150's Avatar
fixnmyf150
Thanks all.
Got a new heater core ($15.00) thought it was going to cost a lot more than that. Replaced it yesterday and what a differance. I now have hot air and quick. The whole project was done in less than an hour.
Would like to thank Ford-trucks for all the help that you have givin me
All of you Guys/Girls rock and will recomend this sight to everyone.
