78 400 Timing chain help.
Old Jan 30, 2018 | 02:09 PM
stroken7.3's Avatar
stroken7.3
I’m getting ready to replace my timing chain on my 400. If I get a set that has +4, 0, -4 where do I set it to be “straight up” and take the factory emissions retard out of the cam? I’ve looked around but I can’t seem to find out an easy answer to it.
Old Jan 30, 2018 | 02:31 PM
79F150400M's Avatar
79F150400M
Straight up would be at 0.
Old Jan 30, 2018 | 02:35 PM
stroken7.3's Avatar
stroken7.3
And that will take out the factory cam retard?
Old Jan 30, 2018 | 02:36 PM
79F150400M's Avatar
79F150400M
Yes that would be correct. Would you also be putting in a bigger cam?? That will wake up your 400.
Old Jan 30, 2018 | 03:14 PM
stroken7.3's Avatar
stroken7.3
Nope, I just picked up a 78 460 out of a F-350 2wd with 54,000 original miles that I’ll be putting in this summer. The 400 is only staying till then but it needs a timing chain.
Old Jan 30, 2018 | 04:01 PM
79F150400M's Avatar
79F150400M
Very cool. The 76 F350 in my avatar needs a healthy 460....the one thats in there is tired.
Old Jan 30, 2018 | 05:41 PM
burnthelight88's Avatar
burnthelight88
Where do you live, its not in your signature? I may be in the market for a 400 if its not a "cracker".
As said before, straight up is 0. I did this job about a year ago, not too bad as long as all of your water pump studs come out, mine where a bit rusty and I broke 2. The water pump studs are all different lengths, so make sure you keep them in order. My biggest alternator bolt wouldn't come out without cutting it off either.
Old Jan 30, 2018 | 09:05 PM
stroken7.3's Avatar
stroken7.3
I’m in Utah. I’m going to hang on to that 400 and try to find my daughter a 78-79 F-150 roller to build with her, she gets her permit in November and she loves my 78 more than my 11 Ecoboost.
Old Jan 30, 2018 | 10:11 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
burnthelight OP is in UT. Mouse over the username, left click once, click on view public profile, click on about me to see location.
X2 on cardboard map the water pump bolts placement. They are different and need to go back where they came from.
Also make note of which ones are in your plate cover, you do NOT want to over torque them.
Old Jan 31, 2018 | 12:20 AM
SDDL-UP's Avatar
SDDL-UP
My youngest son is twelve and I'm looking to do the same thing. He's very mechanically inclined and would LOVE to build up his first vehicle. His older brother has a 78 F-150 and I have a 78 Bronco - he wants to "join the club"!
Old Jan 31, 2018 | 08:13 AM
Aaron-71's Avatar
Aaron-71
Stolen from another post.. but it applies.
https://www.ford-trucks.com/forums/n...ply&p=12174260
Originally Posted by pat67shorty
This is my C. M should be the same.
Old Jan 31, 2018 | 03:17 PM
burnthelight88
I always just look for it in the upper right hand part of the post. I know how to get to profiles, just didn't realize that it would be in the profile but not show on his posts, my bad.
Old Jan 31, 2018 | 05:10 PM
77&79F250's Avatar
77&79F250
I think the location being there all depends on if a person sets up a profile?
artscott61
Apr 3, 2019 04:25 PM
Red1111
Mar 16, 2017 06:37 PM
justforkicks
Mar 25, 2009 09:33 AM
Scolesy
Mar 10, 2008 04:48 PM
ErrorS
Sep 13, 2007 09:32 PM
