blwnsmoke Def issue resolved?
Old Jan 29, 2018 | 07:27 AM
T diesel's Avatar
T diesel
DEF frustrations - Ford Powerstroke Diesel Forum
Did you figure it out?
Old Jan 29, 2018 | 08:02 AM
troverman's Avatar
troverman
I'm not the person with the problem, but I'm curious as to the outcome as well. The EPA should be thrilled with all the extra DEF usage helping remove NOx though!
As a side note, my first 2017 (a dually) seemed to use considerably more DEF than either of my 2016 diesels. I assumed that was the reason for the tank size increase. My second 2017 (a SRW) seems to be using virtually none. I've got over 3k miles on the truck an according to the gauge I've used maybe 1/8 of the DEF tank.
Old Jan 29, 2018 | 08:11 AM
Spoojr's Avatar
Spoojr
Same here...my truck seems to be sipping DEF. (No complaints here...I thought there was something wrong)
Old Jan 29, 2018 | 08:25 AM
tubaphysics's Avatar
tubaphysics
My 2011 F250 and now 2017 F350 Dually seem to use about the same amount of DEF. The dually is doing a lot more hauling of heavy loads so I am not sure how that would play into the equation.
Old Jan 29, 2018 | 08:43 AM
Blwnsmoke's Avatar
Blwnsmoke
Just hit 1100 miles since they filled it. Still shows Def is ok. It was around this time the half way warning triggered so I'm checking every day I drive it which isn't much.
Old Jan 29, 2018 | 06:34 PM
17superduty's Avatar
17superduty
What was the solution ?
Old Jan 29, 2018 | 07:27 PM
Blwnsmoke's Avatar
Blwnsmoke
No solution, dealer didn't do crap. Waiting to see if it triggers again.
Old Jan 30, 2018 | 05:56 AM
17superduty
Great. That's reassuring.
Army RET
6.7L Power Stroke Diesel
25
Jun 26, 2019 08:25 AM
Rogue F350
Jan 2, 2018 11:58 AM
ndecker2
Dec 15, 2016 09:12 AM
Nighteyez
Aug 26, 2013 10:02 PM
Waldo1
Mar 8, 2010 10:33 AM
