I serviced the 435 in my 69 today cause i really cant remember the last time it was done.
I took the easy way and took out the shifter and poured the oil down the neck.
I noticed that the oil weeps out of the top of the shift tower around the lock ring for the shifter.
Is there anyway to keep this from happening.?
"El Stinko" does not smell up the cab to much in the winter but when it gets hot then you get that famous gear lube smell in the cab.
