02 V10 6 speed 4wd transmission questions
I am doing some mixing and matching of components here. And there is little good info out there. I have a 75 F250 2wd with a 360. I am working with an outfit that makes adaptors to put ZF transmissions behind FEs. They said a 02 ZF6 will work fine with their adaptor. The part I am finding little info on is the tail end. I want to use a pre 98 ZF park brake assembly. They supposedly bolt right on to 4wd transmissions in place of the transfer case effectively converting it to 2wd. The pre 98 version of the brake unit has a socket and gear for a mechanical speedo. Found a guy in my area with a 4wd ZF6 for sale cheap. but he was saying that there was a split in the output shaft at some point. anyone know for sure?
99xjon
03-29-2015 07:28 AM
fromm
07-20-2011 08:37 AM
lisagoud
09-27-2009 09:58 PM
jackndelphine
06-22-2008 06:57 PM
