my tailgate won't open
Old Jan 28, 2018 | 11:53 AM
66f-100's Avatar
66f-100
I've had my '66 long bed for years and never had a problem opening the tailgate but now it won't open. When I operate the latch, it appears that one side is releasing but the other is not. Any tips on how to get it open?
Old Jan 28, 2018 | 12:02 PM
AZSCAWPION's Avatar
AZSCAWPION
You'll have to remove the latch handle. When you do, there are 2 rods that operate the latches (1 extends to the left, 1 to the right). You can pull inward on the one that is disconnected or broken.
Old Jan 28, 2018 | 12:03 PM
6t6merc's Avatar
6t6merc
You can remove the latch and pull on the rod. After it's open you can disassemble the mechanism and shorten the rod by bending it.
Eric
edit: You beat me, AZ.
Old Jan 28, 2018 | 12:10 PM
66f-100's Avatar
66f-100
thanks for the replies, I will try it
Old Jan 28, 2018 | 12:11 PM
AZSCAWPION's Avatar
AZSCAWPION
WooHoo! First in something! Looks like it's gonna be a good day.
Old Jan 28, 2018 | 07:56 PM
john jamieson's Avatar
john jamieson
Don't the rod ends thread into a swiveling stud on the handle assembly? If that stud came off the assembly the one side would not be operated by the handle
Old Jan 28, 2018 | 11:50 PM
RangerMercMan's Avatar
RangerMercMan
I was taught that over time the metal wears down on the handle where it contacts the pivot. Get in there with a welder (yes it is hard but you just feed a lot of wire out to get in). Build up the pivot area with ugly looking weld and your problems will be fixed.
Stockdale Dave
Mar 16, 2017 07:01 PM
beautyandthebeast
Dec 1, 2015 08:00 PM
LawBoy01
Jun 26, 2014 06:22 PM
SMS888
Dec 3, 2012 08:08 PM
xirxious
Aug 22, 2009 03:59 PM
