Stuck tailgate
Old Mar 14, 2017 | 09:16 PM
Stockdale Dave's Avatar
Stockdale Dave
Stuck tailgate
My tailgate on the 84 SWB is stuck in the closed position. Pulling the handle lets the left side release a little but the right side is stuck fast. I have spayed PB Blaster through the crack to try to loosen up the catch mechanism without luck. There are no removable access panels on the bed side of the tailgate. Has anyone seen this issue? Thought maybe I could remove the passenger side tail light to see if an access hole was there but no joy. Any tips?
Old Mar 15, 2017 | 07:54 AM
Lord Vokk's Avatar
Lord Vokk
Hey, Are both your 'rods' still firmly in place in the tailgate handle? I had one of the retainer clips come loose and the rod popped out of the actual tailgate handle.
Old Mar 15, 2017 | 08:57 AM
Gary Lewis's Avatar
Gary Lewis
I agree - the rod has probably popped out or the clip has broken. Pull the handle by removing the screws inside the tailgate and you'll see both rods.
Old Mar 15, 2017 | 09:20 AM
1986F150six's Avatar
1986F150six
Look up by the handle. If one rod is loose [broken plastic clip], the rod [which is horizontal, by the way] can be pulled using pliers. This will open the tailgate.
The plastic clips can be purchased @ Ford dealer or parts houses in the HELP section.
Old Mar 15, 2017 | 07:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The plastic clips (21952 in pic) can be purchased @ Ford dealer or parts houses in the HELP section.
Lower pic showing the right side parts of the 1983/86 F100/350 tailgate.
Old Mar 15, 2017 | 08:56 PM
Toddster's Avatar
Toddster
If one or both of the rods have broke free from the handle like the guys have already said you can reach underneath and pull both or one of them with your hand and open the tailgate. The rods on my original tailgate were bent so I had to use a screwdriver and from the inside of the bed I pushed the latches in one at a time and got it open. Hope that helps!
Old Mar 16, 2017 | 07:01 PM
Stockdale Dave
Good call guys... The top rod had popped out of the handle. Probably should have looked harder.
Bluegrass F250
Sep 3, 2020 10:45 PM
LawBoy01
Jun 26, 2014 06:22 PM
xirxious
Aug 22, 2009 03:59 PM
1973FordF100
Oct 28, 2008 02:05 PM
DieselRunner
Nov 26, 2006 03:04 PM
