Daytime Running Lights
Old Jan 28, 2018 | 04:30 AM
GaryKip's Avatar
GaryKip
Does anyone know how I can disable the daytime running lights on my 2011 F150 xtr 4 X 4 from Canada? The VIN is 1FTFW1EFOBFC80658, which shows it was made in USA (right?). But it has a "built in Canada" sticker on the drivers door.
Old Jan 28, 2018 | 07:16 AM
Bruker's Avatar
Bruker
It's my understanding that the DRL feature can only be enabled or disabled by a dealer tech.
Old Jan 28, 2018 | 10:45 PM
GaryKip's Avatar
GaryKip
Well crap, I was hoping that it would be something simple like just removing the DRL relay. But if that's what I have to do - so be it. Thanks for the reply. I'll contact the dealer and let everyone know if there is another way or not.
Old Jan 29, 2018 | 05:17 AM
Siberexpress's Avatar
Siberexpress
You can try Forscan, I used it to turn off the DRL in my 2013 FORScan Home
It is a free program, you will just need to get the adapter and they tell you what you need.
But on my E150 I gave the guy $20 at the local Ford Dealer.
Old Jan 29, 2018 | 08:13 AM
WXboy's Avatar
WXboy
I used ForScan and a $20 OBD Bluetooth adapter to kill the DRLs on my truck. You can do lots of other things with that software also.
Old Jan 29, 2018 | 10:50 AM
Olytlr's Avatar
Olytlr
You can disable them or change them to your fogs or signals for DRLs if you want with Forscan. Your truck was not built in Canada. Your door sticker should have a maple leaf on it which means it was built for the Canadian market but wasn't built in Canada.
Old Jan 29, 2018 | 07:20 PM
fastback89's Avatar
fastback89
I used Forscan to change them to my fog lights
Old Jan 31, 2018 | 02:38 AM
GaryKip's Avatar
GaryKip
Ok I understand it now. Yes it does have the maple leaf sticker. Thank you for clearing that up. The salesman didn't know that either.
Old Feb 2, 2018 | 11:56 PM
GaryKip's Avatar
GaryKip
Great news! I found a way to disable the DRL on "Utube" where all I had to do is unplug the connectors that are behind the splash shield on the front side of the rad support. But thank you for the info about Forscan. Cause I still need to delete the speed limiter (it's set at 100MPH right now).
Old Feb 3, 2018 | 08:52 AM
Olytlr's Avatar
Olytlr
You may have done something else as well. Your disconnect method works for 2010 and prior but 2011+ trucks use a BCM that controls the DRL function.
The speed limiter is there for a reason, but if your dead set on changing it, you would need a tuner. Forscan can't do it.
Poncho450
Mar 20, 2016 09:18 AM
CA-F250
6.7L Power Stroke Diesel
Oct 6, 2010 06:37 PM
mlbmd
Feb 7, 2009 08:39 AM
jeffnick
16
May 4, 2006 11:11 AM
