Disable bulb out warning “hyper flash”
Old Feb 18, 2018 | 03:02 AM
  #61
mikemorales's Avatar
mikemorales
Originally Posted by Poncho450
Glad to see that you found an answer to the problem and saved yourself a few bucks to boot.
appreciate that. The jdm are very close in terms of brightness to the gtrs so I’m very pleased with them.
Old Feb 18, 2018 | 06:45 AM
  #62
jsavelli's Avatar
jsavelli
Juse an fyi. All my leds are in and all work great. I posted a littLe bit ago the couple more I just got and finally finished the front grille fabrication. Still having 8ssues w stereo mods....shuda went old school on that and not depend on others w no results
ults
Old Feb 18, 2018 | 06:52 AM
  #63
mikemorales
ults
looks great! I think my last light mod for now will be some led strips to light up the running boards. I have the proper connections under my truck so I should have this done soon.
Old Feb 18, 2018 | 08:46 AM
  #64
jsavelli's Avatar
jsavelli
I l did mine first. Used metra harness and n mictuning strips wipe w alcohol and put up in groove under door jamb fits perfect
Old Feb 18, 2018 | 09:18 AM
  #65
mikemorales
that’s exactly the look I’m going for. Debating if I want to go with a white or blue light under there.
Old Dec 20, 2018 | 05:47 AM
  #66
dlyst13's Avatar
dlyst13
2017 Super Duty hyperflash
So I had Ford do the flash on my 2017 f350 to prevent the hyperflash, before I put in my LED tail lights. Once I put those in, they blink as normal but the dash still hyper blinks. Does anyone know if that is supposed to be the case once Ford flashes it? I don't have anything on the dash indicating a bulb out, just the hyper flashing arrow, which drives me crazy. Any help would be appreciated.
Old Dec 20, 2018 | 06:07 AM
  #67
user 474747383's Avatar
user 474747383
Old Apr 20, 2024 | 09:08 PM
  #68
Summers22's Avatar
Summers22
I did the Forscan changes and still have the dash hyper flash, bulbs all flash normal. I am not new to Forscan and changes, so I am at a loss........
Old Apr 21, 2024 | 06:42 AM
  #69
morehouse7's Avatar
morehouse7
I was never able to get mine to resolve either, same issue as you. I haven't looked at it in a long time, but would like to fix it.
Old Apr 21, 2024 | 07:07 AM
  #70
Summers22's Avatar
Summers22
I have found this bit of information, I'll try it later today and report back, I think ABM outage cnfg is what is the one that will solve it for us :
Old Apr 21, 2024 | 07:46 AM
  #71
morehouse7's Avatar
morehouse7
And to further clarify my dash only does it at night when my other lights are on.
Old Apr 21, 2024 | 12:09 PM
  #72
Summers22's Avatar
Summers22
Here is a screenshot of what to change in as-built for BdyCM, I just made the change and it worked with this line change (changing turn lamp dtc operation did not help).
OverHeight
Feb 2, 2019 08:30 AM
abe
21
May 10, 2018 11:10 PM
Scotty's 52 F3
17
Sep 9, 2015 08:45 PM
lexustbs
6.7L Power Stroke Diesel
Jan 26, 2011 11:07 AM
first_f250
Jun 30, 2010 12:45 PM
