How to remove the harmonic balancer?
Old Jan 25, 2018 | 06:22 PM
genscripter's Avatar
genscripter
Hi all, I only got my cell today (No laptop) so it's hard to search. Can someone show how to pull the harmonic balancer off? Or forward a link? Do I need a pulley puller or similar?
also is my balancer supposed to look so deteriorated on the inside?
Old Jan 25, 2018 | 06:50 PM
cadunkle's Avatar
cadunkle
https://www.autozone.com/loan-a-tool...ler/555524_0_0
Old Jan 25, 2018 | 06:53 PM
cadunkle's Avatar
cadunkle
Also note that balancer is no good, the rubber is cracked and broken down. The outside ring can slip and give incorrect timing readings and depending on where the imbalance is it can put the engine out of balance and result in vibration, or lead to crank failure (more in the case of high RPM engines).
Rubber can be replaced to restore a balancer, there are several companies that do this and I think there may be kits to DIY. Maintaining correct orientation of the inner and outer parts is critical though.
Old Jan 28, 2018 | 01:08 AM
hairyboxnoogle's Avatar
hairyboxnoogle
That puller kit is also like $15-20 at harbor freight, which is what i used to remove mine. My balancer showed some weathering as well, but not as significant as yours.
Sevillian273
22
Dec 12, 2011 08:15 PM
jj22ee
Feb 25, 2011 07:37 PM
dfwrider
23
Feb 13, 2009 06:01 AM
beartracks
Jan 25, 2009 04:14 PM
