Sponsored by: Auxito
Reverse
Old Jan 24, 2018 | 06:26 PM
mhoward180's Avatar
mhoward180
Reverse
I started backing up and my reverse gear seemed to lock up. All forward gears work. The gear shifter appears to move through the gears without issue. When I shift into reverse the truck feels as though it is locked up. Got no idea what is wrong. The four wheel drive has been inoperable for a year or so but I don't know if that matters for this problem.
Old Jan 24, 2018 | 07:17 PM
Chad T. Keogh's Avatar
Chad T. Keogh
Is it manual transmission? Did you recently have work done?
Old Jan 24, 2018 | 07:18 PM
Chad T. Keogh
It could be a reverse gear failure, or if anyone was trying to check your manual transmission fluid, and took out the wrong bolt, the gear may have fallen off the shaft.
Old Jan 24, 2018 | 07:21 PM
mhoward180's Avatar
mhoward180
It is an automatic, and has been running well.
Old Jan 24, 2018 | 07:25 PM
mhoward180's Avatar
mhoward180
Sorry, I see now I made it seem like a manual transmission. I meant the lever for the PRNDL.
Old Jan 24, 2018 | 07:54 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
With the engine running and the shift handle in N will the truck try to move forward? Can it roll backwards in this condition?
Old Jan 25, 2018 | 11:02 AM
mhoward180's Avatar
mhoward180
With the engine running it will shift into neutral normally and will roll backwards freely.
Old Jan 8, 2022 | 10:08 PM
Silvermaver1ckjt's Avatar
Silvermaver1ckjt
Help
did you ever fix. My truck is doing the same thing.
gravel pit camper
2004 - 2008 F150
Oct 12, 2011 10:32 AM
Knightrocker
2004 - 2008 F150
Jan 25, 2010 10:30 PM
jamerson
Feb 16, 2004 09:00 PM
nogo73
Aug 11, 2003 01:08 AM
Leland
Apr 8, 2002 02:42 AM
