I started backing up and my reverse gear seemed to lock up. All forward gears work. The gear shifter appears to move through the gears without issue. When I shift into reverse the truck feels as though it is locked up. Got no idea what is wrong. The four wheel drive has been inoperable for a year or so but I don't know if that matters for this problem.
It could be a reverse gear failure, or if anyone was trying to check your manual transmission fluid, and took out the wrong bolt, the gear may have fallen off the shaft.
