Broken fuel filter cap
Old Jan 24, 2018 | 05:06 PM
Hookedsouthernstyle's Avatar
Hookedsouthernstyle
First turn with a 1/2" socket drive broke 2 sides off. Another try with channel locks and another section broke.
0 for 2...
​​​​​​any suggestions?
Old Jan 24, 2018 | 07:52 PM
Red97350's Avatar
Red97350
Screw in 2 lag bolts and pry against those with a bar? Did you drain any out of it before you tried to open it? That may break the suction/ pressure.
Red
Old Jan 24, 2018 | 08:17 PM
Hookedsouthernstyle
Red
I did, but then gave up and had to go to work. lag screws sounds easy enough . I wasn't sure what was under the cap. I have a new one on order and it should be here tomorrow .
Old Jan 24, 2018 | 08:42 PM
Red97350's Avatar
Red97350
You may screw up the filter, but your changing that anyways. You could also try a chisel and tap on the side of the cap, but I would be worried about breaking the feet on the filter housing.
Red
Old Feb 4, 2018 | 07:22 PM
Hookedsouthernstyle
Red
Chisel worked fine. Turns out that whoever changed the fuel filter before did not put o-ring on.... which explains why it was so tight.
06 F-350 King Ranch
Apr 18, 2018 07:49 PM
scatgo
Jun 29, 2008 01:56 PM
tndiesel
Nov 6, 2007 08:12 AM
TJ Shaw
Jun 14, 2007 09:08 PM
Mindstream
Jan 8, 2007 03:26 PM
