Battery problem
Old Jan 24, 2018 | 03:45 PM
Bulldog187th's Avatar
Bulldog187th
Battery problem
brand new red top, new 90 amp alternator,
Fired it up checked voltage 14.5 volts so its charging .
Came back out the next day to finish tuning , went to start and click click click on starter relay ( which is new) checked voltage on battery 8.6 volts.
Placed on charger last night now reading 12.5 volts , truck fired right up. Still showing 14.5 volts charging.
So way the low voltage the next morning?
Old Jan 24, 2018 | 03:53 PM
Filthy Beast's Avatar
Filthy Beast
Obviously, something is draining the battery.
Pull the negative (-) battery cable and watch for any kind of spark that might occur. Touch the cable to the negative (-) battery post....any spark?
My first thought would be the starter solenoid might have the contacts welded together..... smack it with a screwdriver handle a coulpa times....check for spark again......? But, more troubleshooting could be the case here.
Have a spark? Leave the battery disconnected overnight and check it in the morning.
Old Jan 24, 2018 | 04:07 PM
FuzzFace2's Avatar
FuzzFace2
Ok let think this thru.
If the starter solenoid had welded contacts then the starter would also be turning over or spinning with the motor running.
So I would say it is not the solenoid.
I am for removing the neg batt cable but better then looking for sparks, this can cause the batt to blow up so not a good thing to do.
Is to use a test light between batt & cable. Bright light and you have a lot of draw, dim light little draw.
With the light on start pulling 1 fuse at a time till the light goes out and that is the area you need to look for the draw.
Now if pulling fuses does not do the trick remove the wires 1 at a time from the ALT and see if the test light goes out. If so bad ALT and yes even new they could be bad and still put out volts.
Dave ----
Old Jan 24, 2018 | 04:43 PM
Bulldog187th
Will I do remember seeing spark from the cable when I stuck the new battery in. So I guess I have a short.
So now onto following the fuses like you said.
Old Jan 24, 2018 | 05:59 PM
FuzzFace2's Avatar
FuzzFace2
With the test light.
And again if fuses don't pan out look at the ALT for bad diodes.
Dave ----
Old Jan 24, 2018 | 06:27 PM
Bulldog187th
Will I went out to check and battery is back down to 9.45 from the 12.4 from this morning. So right now I have it back on charger.
But before I placed the charger back on I unhooked the neg and saw no spark when taking it off. I then connect neg on light to neg on cable while still disconnected and touch the other end of the light to pos on battery light seemed bright for the amount of voltage left in battery.
I will do it again when battery is fully charged.
Old Jan 24, 2018 | 06:32 PM
FuzzFace2's Avatar
FuzzFace2
You want to put the test light between the NEG cable and the NEG batt post NOT the POS batt post.
When testing with the light make sure everything is off and doors closed.
Dave ----
Old Jan 24, 2018 | 06:35 PM
Bulldog187th
Dave ----
Ok I did that first and had no light so I had thought i did it wrong , being why I did it the other way also
Old Jan 24, 2018 | 06:48 PM
Tedster9's Avatar
Tedster9
Put your hand on the alternator in the morning and see if it feels warm. If battery is drained overnight that's a pretty good draw coming from somewhere, and a bad diode will do it.
77F100stepside's Avatar
77F100stepside
A place to check for draw if it's not the alt is your radio. This is if it's been upgraded to a digital one. If installed wrong it might be drawing full power all the time instead of just enough to store presets.
Old Jan 24, 2018 | 08:25 PM
Bulldog187th
ok will do.
Old Jan 24, 2018 | 08:27 PM
Bulldog187th
Will do . Its almost at full charge now, i'll unplug charger before bed.
lol I wish right now I dont have a radio in it.
Old Jan 24, 2018 | 08:54 PM
77F100stepside
Oh. Lol. Hopefully the build goes well!
Is the dome light in? If so check id check it.
From memory these are all the full time power functions.
Dome/Cargo light
Hazard lights
Altenator
Starter solenoid
Horn and horn relay
Brake lights
Mack
Old Jan 24, 2018 | 09:02 PM
Bulldog187th
Dome/Cargo light
Hazard lights
Altenator
Starter solenoid
Horn and horn relay
Brake lights
Mack
Cargo lamp is in but looks to be all broken up . I have a new led one to stick in just have not gotten to it.
brake light are not hooked up because bed is off , but maybe connection wire is laying on frame , um I'll check that when I go out to unplung charger.
Alternator is new and starter relay .
Crap I just thought of something, the person I got this truck from has another starter relay on the driver side for extra battery and the cable might be toughing something because its not hooked up to a battery.
The wires are just laying around. I have not got to that yet.
Oh man your making really think tonight lol , also my whole dash is out because Im replacing it all maybe a wire in there touching.
Old Jan 24, 2018 | 10:59 PM
Tedster9's Avatar
Tedster9
Crap I just thought of something, the person I got this truck from has another starter relay on the driver side for extra battery and the cable might be touching something because its not hooked up to a battery.
The wires are just laying around. I have not got to that yet. Oh man your making really think tonight lol, also my whole dash is out because I'm replacing it all maybe a wire in there touching.
Be careful. I'd disconnect a battery completely if the wiring harness shorting out is a concern, esp. if the truck is in an attached garage. Fires are not cool. Maybe being a little paranoid, but.
Another thing to keep in mind is that an automotive starting battery will only handle being heavily discharged like that a handful of times before it's junk, they don't like that at all.
