I have an issue with my blind spot warning with my trailer, it is within the proper length, but blind won't turn on, when I go into setup to turn it on, it says, no conventional trailer saved. I hope I don't have to delete it and start over as I caught up my milage.
I just watched that vid and it says you have to select the trailer profile with the BLIS configured for it to work, if you connect the trailer first it will not. Which way did you connect?
This happened to me. Go to the regular settings tab (not trailer) and make sure the trailer blind spot option is checked off
thanks some how that got turned off. Now I guess I'll have to test the trailer to see if it works. Still doesn't want to save it as conventional, so I guess I have to delete and start over to see if it works. I think it worked initially 2000 miles ago. Also added a new tt to test, won't save it as conventional as far as blis is concerned. Ok checked when I got home and after several restarts now it says that the blis is ready, dont know what I did, but will hook up the tt tomorrow and test it.
