General Automotive Discussion
Crazy idea
Old Jan 23, 2018 | 11:58 PM
hjartland's Avatar
hjartland
Crazy idea
This idea may seem crazy now, but I challenge YOU. Yes You to come up with a possible solution for every problem you mention!
What if someone came out with an electric hub motor for 2-wheel drive trucks & vans?
One that would bolt-on in place of the spindle and brakes. This would serve 2 purposes.
#1 It would provide front-wheel assist at low speeds. Much like 2-wheel drive tractors can have front-wheel hydraulic assist. It provides a substantial amount of help when it is needed. Like when it's stuck in the mud, snow, old bras, emotional baggage. You know. The usual.
#2 Turning braking resistance into usable power. Just like in regular electric vehicles. This would charge a battery bank for any number of use. Like acting in a 1/2 hybrid role by providing power to the front wheels.
I know there are a lot of problems to overcome. But try to respond with a possible fix for any issues you bring up.
Let's see what comes of this crazy idea!
Old Jan 24, 2018 | 12:03 AM
hjartland's Avatar
hjartland
Commercial
This could find a lot of use in the commercial delivery truck/van market.
Old Jan 27, 2018 | 07:07 AM
Chuck's First Ford's Avatar
Chuck's First Ford
replace the front spindle... add motor .
or replace brake rotor with a rotor with a ring gear... like a flywheel/starter setup.
I think you could have a market.. the price point will be an issue..
as the aftermarket overdrive add-on box is still being made..
I also see a few.. changing a 2 wheel drive truck to 4 wheel using used factory parts.
Old Jan 27, 2018 | 03:09 PM
hjartland's Avatar
hjartland
Nice.
I really like your point about a ring gear & starter type solution! Some little geared down version could give one the low speed assist when needed w/o the weight of a factory 4x4 front end.
Nice input!
Old Jan 27, 2018 | 11:25 PM
ford2go's Avatar
ford2go
I keep coming back to 2 large and heavy motors that have to turn and bounce as you travel about. Unsprung weight is not good.
The only way that I can see the ring gear setup avoiding that is if it would only work when the wheels were straight. Even then the motors would have to move vertically.
Not being any kind of mechanical genius ( or even a mechanical average ), I can only see one way out. Put a motor in the center and use it like a normal 4wd setup with axles and CV joints.
Porsche and some other high buck aompanies have some 'hybrid' autos that use the electric to increase power output. But, from the little that I could find, they just run the electric motor output through the normal drivetrain.
Not trying to be a downer -- be happy to be proven wrong,
hj
Old Jan 28, 2018 | 12:36 AM
hjartland's Avatar
hjartland
That's not a downer. That is good positive input. TY.
If the small-geared down motor road on the spindle. It could run at anytime.
Old Jan 29, 2018 | 09:20 AM
Chuck's First Ford
as for the added weight at the wheels..
has anyone weighted a 17 inch wheel/tire.. and the 20 plus sizes... heavier..
the starter/gear at the rotor.. would rotate/angle just like the brake caliper.. so steering has no affect ..or bumps..
price and demand is the issue. but adding a few hundred pounds to a 7,000 pound plus truck is minimum
if you go with my idea... just add my name to it
Old Jan 29, 2018 | 01:11 PM
85e150's Avatar
85e150
120 years ago....
https://en.wikipedia.org/wiki/Lohner-Porsche
https://en.wikipedia.org/wiki/Wheel_hub_motor
Considerable development, no hub motor:
S-AWC | Innovation | MITSUBISHI MOTORS
As a retrofit, yes, it's a crazy idea.
Old Jan 29, 2018 | 02:18 PM
Chuck's First Ford
as for crazy ideas..
early Honda Goldwings... someone made an sold a reverse setup.. electric motor and a rubber wheel.. cable and bracket..
pulling lever had motor/wheel pivot up and rubber wheel to rear wheel of bike.. it moved backwards...
sold many for years...
in 1988 Honda redesigned the Goldwing.. and used the transmission/engine starter with a computer to control speed.. as standard equipment...
Old Jan 29, 2018 | 05:09 PM
hjartland's Avatar
hjartland
Some got it. Others didn't.
The trouble with the internet is short sighted & narrow minded people.
Then there are some who can see passed what is out there. Envisioning a possibility ywt to be recognized.
It is nice to know there are still others who are open minded.
Thank you for your input. Maybe we'll see such a system rolling down the road one day and be glad we didn't close our minds.
Old Jan 30, 2018 | 07:46 PM
85e150's Avatar
85e150
Are you referring to me as short sighted and narrow minded?
I didn't find this yesterday, but it's exactly what you are talking about.
Overview | Protean Electric
Old Jan 31, 2018 | 02:48 AM
hjartland's Avatar
hjartland
Apologies
Apologies. My bad.
James Wagoner
29
Feb 14, 2018 08:02 PM
1'snotenuf
May 21, 2013 02:15 PM
tastyklair
Electrical Systems/Wiring
Jun 21, 2008 01:47 PM
terrypen
Aug 20, 2006 08:26 PM
fast77
Bronco II
Jan 18, 2002 06:57 PM
