General Automotive Discussion
Transmission problem
Old Feb 1, 2018 | 10:18 PM
Kenneth Nash's Avatar
Kenneth Nash
I have a 91 F250 custom 7.5 L 460 V8 four-wheel drive my transmission likes to kick out of 3rd gear if I accelerate hard or if I'm not holding the holding the shifter up in third as I shift out of 3rd into 4th I'll hit 4th and it will grind and and then it'll go in to 4th but as I let out the clutch it grinds like it's not in 4th but if I put the clutch back in and kinda plam it in past the grinding and then let the clutch out it works and it will stay in 4th gear what is my problem it'll shift into 5th just fine the truck does have an self adjusting clutch was told it's the linkage between 3rd and 4th gear
Old Feb 2, 2018 | 06:34 AM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE
sounds like it is time to pull the trans for a rebuild.
third gear sounds like a problem with shifter fork, and 4th sounds like work syncro gears.
Old Feb 2, 2018 | 08:16 AM
Kenneth Nash
thank you yes I was thinking about getting a new tranny just didn't Want to if I didn't have to can it be my clutch do u know if my hydraulic clutch needed to be bled i guess I got to find a tranny I do a lot of cattle hauling so I don't know if I can do an upgrade on a transmission it's a 5 speed with overdrive any ideas
Old Feb 2, 2018 | 09:42 AM
tjc transport
i ain't rite
5 speed is all you will get. or spend a lot of money and put an allison truck automatic trans in it
Eddillard79
20
May 3, 2016 07:01 AM
JPMallory
Aug 2, 2014 09:51 AM
RhinoScores
1983 - 2012 Ranger & B-Series
Nov 30, 2006 10:10 PM
Neurotoxin
13
May 31, 2003 09:50 PM
19Jed52
May 15, 2000 03:56 AM
