Engine swap ideas ‘88
Old Jan 22, 2018 | 09:46 PM
Gabcar8321's Avatar
Gabcar8321
Does anyone know if its a good idea to swap 4.9 l i6 for a 281 (4.6) from a p71 crown vic into a 1988 f150??
Old Jan 22, 2018 | 10:10 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Doable if you are wealthy enough and stubborn enough, but IMHO, bad idea.
Old Jan 22, 2018 | 10:13 PM
Conanski's Avatar
Conanski
it is not a good idea if you're looking for a quick, cheap, and easy project.
Old Jan 23, 2018 | 07:06 AM
Gabcar8321's Avatar
Gabcar8321
what would be. A quick, cheap, and easy project? The truck has been sitting for 10years + and it won’t start. I assume its the ECU and i bet theres a whole bunch of wiring issues. But there is spark, and fuel delivery.
Old Jan 23, 2018 | 10:38 AM
NotEnoughTrucks2014
Don't assume anything!
If you have spark and fuel delivery, it would seem more likely that that your ECU and wiring are just fine.
Old Jan 23, 2018 | 03:50 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by Gabcar8321
....there is spark, and fuel delivery.
If there is spark and fuel and won’t start are you in a vacuum ie no air? Check for codes and start doing some diagnostic work. How old is the fuel? If you are trying to burn the 10 year old “fuel” that could be a problem.
Old Jan 23, 2018 | 08:07 PM
willowbilly3's Avatar
willowbilly3
My thoughts too. ECUs just don't go bad that often but 10 year old gas wouldn't burn if you threw a match on it.
Old Jan 24, 2018 | 07:57 AM
'89F2urd's Avatar
'89F2urd
4.6 in anything
Pull codes before you rid yourself of the i6 just to get it running....if you want more power, the 4.6 isn't the answer.
Old Jan 24, 2018 | 08:08 AM
Gabcar8321's Avatar
Gabcar8321
Both tanks had holes so im using one of the portable red ones.The engine only ran once and thats when i poured gas through the intake but it quickly died.
Old Jan 24, 2018 | 08:09 AM
Gabcar8321's Avatar
Gabcar8321
Originally Posted by '89F2urd
4.6 in anything
will do!👍🏼
Old Jan 24, 2018 | 11:11 AM
My4Fordtrucks
So you are trying to draw the fuel from a gas can using the frame mounted pump?
Old Jan 24, 2018 | 09:09 PM
Gabcar8321's Avatar
Gabcar8321
yes sir i am
Old Jan 25, 2018 | 03:19 AM
NotEnoughTrucks2014
yes sir i am
So, the fact it runs when you spray gas in the intake says you do not have fuel delivery. Check to make sure your fuel pump is running and check fuel rail pressure with a gauge.
Running off an external tank with the frame mounted high pressure fuel pump is possible, but the factory tanks also contain pumps that deliver fuel to the HP pump. It's not a great lift pump, so set your portable tank higher and set up a siphon feed or use a low pressure electric pump between the tank and the HP pump. Also don't forget your return line which is delivering excess fuel back to your leaky original tanks.
Thomsponmichael
Jan 27, 2020 11:48 AM
backyard bogger
Sep 8, 2010 10:23 PM
Mad_scientist_custom
Jan 18, 2010 10:47 PM
derbinator
Engine Swaps
Oct 5, 2004 11:40 AM
FordPerf300
Aug 7, 2002 05:21 PM
