Smoke, then clears up
Old Jan 22, 2018 | 07:16 PM
Maltman's Avatar
Maltman
Hi all, problem started Saturday morning.
I warm my truck up for 2-3 minutes, drive about 4 blocks (no issues) and I see white/grey smoke coming out of tailpipe-always starts smoking in same location. EOT and ECT are 125-135, I can drive it for another block and it clears up, only smokes at idle and light throttle. Once it clears up (quickly) will not do it for the rest of the day driving around.
My mechanic seems to think it could be a turbo gasket......any other idears?
Old Jan 22, 2018 | 08:56 PM
mattdoc88's Avatar
mattdoc88
Have you scanned it for codes?
Do you still have a stock EGR cooler? If so, try the nose-downhill parking test overnight.
Old Jan 22, 2018 | 09:29 PM
Maltman's Avatar
Maltman
No codes and it was Bulletproofed 12k miles ago (preventative)
What is nose downhill test?
Old Jan 23, 2018 | 07:45 AM
navistarnut's Avatar
navistarnut
Park it nose down overnight, pull the EGR the following morning to see if it's wet, a sign the EGR cooler is leaking. Being you are in Cali I'm sure you are not deleted.
Did the bullet proof include a new EGR cooler?
Losing any coolant?
You can pull the downpipe loose to see if it's getting oily, which might point to a turbo shaft seal leaking.
If there is no hint of coolant smell at the tailpipe that might narrow it down more.
Blue smoke=fuel
White smoke=coolant(unless it's really cold, then it's normal......not going to affect you where you are)
Grey smoke=oil
Old Jan 23, 2018 | 09:29 AM
TooManyToys.'s Avatar
TooManyToys.
Badgerproofed, it was badgerproofed.
I went through the same characteristics. There was a small contribution of smoke due a lazy EGR valve if you still use the EGR as working, but the real culprit was an injector that developed stiction. AR9100 helped somewhat, but it required checking the injectors with IDS uncompensated to find the injector, replace it and solve the problem.
Old Jan 23, 2018 | 09:57 AM
Maltman's Avatar
Maltman
Yes, updated EGR cooler with bulletproof. Ill check the downpipe, I did notice more than normal oil around boot closest to turbo.
No coolant smell and smoke is grayish, definitely on the lighter side of blue/black.
I think my tuner deletes EGR? I run rev X for stiction, but will have my mechanic check like you have said.
Thanks guys, just trying to get some idears before taking to mechanic on Thursday
Old Jan 23, 2018 | 12:55 PM
navistarnut
You are not deleted if you still have the EGR cooler, which I figured was the case since you are in Cali.
Some oil in the boots is normal, it's from the crankcase breather and not to worry about unless you are seeing copious amounts.
Old Jan 26, 2018 | 03:01 PM
Maltman's Avatar
Maltman
Turns out it was a bad turbo seal. So I did the only logical thing and upgraded to a KC Turbo stage one.
Old Jan 26, 2018 | 03:38 PM
navistarnut
Sweet turbo.
Let us know how she responds.
Old Jan 29, 2018 | 09:22 PM
Maltman's Avatar
Maltman
After loading updated tunes yesterday.....this thing pulls like a freight train on top end. Spools REALLY fast. Hardly any lag, no smoke and EGTs are lower across the board. Sounds awesome under full boost. I love it.
Benchwrench
Sep 20, 2021 08:02 AM
Oryo
Jan 25, 2021 08:44 PM
shivaskeeper
Jan 25, 2021 12:33 AM
chesterstroker
6.4L Power Stroke Diesel
Jan 11, 2014 08:33 PM
JonArmy
Mar 8, 2012 11:22 AM
