Defroster vent mounting
Old Jan 22, 2018 | 10:14 AM
tractormanbill's Avatar
tractormanbill
tractorman
My truck did not come with screw holes to mount defroster vents and I already had the dash painted and the windshield mounted so I glued the vents under the dash in place with POR 15 seam sealer. I have used it around AC connectors going through a inner fender panel and it is like epoxy and nearly impossibly to remove once it sets up.
TractormanBill
Old Jan 22, 2018 | 10:30 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Did someone fill the original holes? I can't imagine it left the factory without them!
Old Jan 22, 2018 | 10:41 AM
tractormanbill
tractorman
Defroster vents
The truck did not come with a heater but the body man I had working in the cab must have filled them in even though I didn't see or feel any humps on the underside. Anyway I got those babies mounted.
Old Jan 23, 2018 | 07:46 AM
petemcl's Avatar
petemcl
Hope that you never have to remove them.
Old Jan 23, 2018 | 09:19 AM
schoo's Avatar
schoo
I glued mine also (a 49)make sure that the two piece drivers side tube is not glued you need the area where the tube connects to install the gauges and windshield wipers
I got a good one from firstrider
7.3 down
Dec 5, 2013 03:07 PM
Roger T. Pipe
May 20, 2012 02:20 PM
460
Jan 11, 2009 11:40 AM
mitch9705
Nov 17, 2006 09:26 PM
Smurf-Slayer
Oct 10, 2004 07:21 PM
