I need to do some welding on fron mounts. So I think I will remove the front clip on my 51 F3. Does the radiator stay, as well as the inner fenders? How many bolts? Thanks guys.
I was able to remove the bolts at the bottom of the radiator support t the crossmember and then the bolts at the back of the fenders to the cab and everything came off as a unit
i would say inner fender bolts to cab, running board bolts and the two bolts with springs under the radiator cradle. yes inner fenders come off with it.
radiator/core support bolts to crossmember
rear of inner fenders bolt to cab at firewall
bottom of fenders may bolt to running boards (mine wasn't yet)
