Swaping Factory A\C
Old Nov 16, 2006 | 08:53 PM
mitch9705's Avatar
mitch9705
Swaping Factory A\C
Im in the middle of a body swap and was wondering how hard it is to remove the factory A\C. The doner at one time had factory A\c they just put a pice of sheet metal over the hole. Thanks for your help.
Old Nov 17, 2006 | 09:16 AM
bucks77ford's Avatar
bucks77ford
If the hole in the cab of your donor truck has been modified and all you have to do is take the sheet metal off, than swapping the A/C shouldn't be a problem. Does your donor truck still have the A/C dash? If not than use your old A/C dash. You have to strip the dash down anyway to get all the A/C parts out, why not just use the A/C dash. AS your taking apart your old cab, just pay attention on where everything should go and it should go pretty smooth. Just takes time. It's when people have to make a Non-A/C cab an A/C cab is where more of a pain comes into play. You would have to cut that big hole in the cab for the box and also cut the A/C vents in the dash.
Old Nov 17, 2006 | 09:26 PM
march's Avatar
march
I've never totally removed one, but if you start here....... https://www.ford-trucks.com/article/...es_Trucks.htmlyou're probably 90% there.
