56 cab corner replacement advice
Old Jan 21, 2018 | 05:45 PM
brucelee's Avatar
brucelee
Damage from previous accident cut out.
I plan on removing as little metal as possible. Just the lower half of inner cab corner, 3-4 inches of rocket and door piller. Or would it be better to remove outer cab corner all the way around to piller so less welding will be needed? Your thoughts?
Old Jan 21, 2018 | 07:30 PM
pholmes350's Avatar
pholmes350
I bought my new corners from LMC and the two sides that were hardest to line up was the door pillar and the rib on the back of the cab. The replacement has a little different profile on these two areas so they required massaging.
If it were mine i wouldn't cut out the pillar or cut through the rib. Only replace the very bottom where rusted through. Patch fitment is a big issue with every vendor.
Old Jan 21, 2018 | 07:43 PM
Greg Rogers's Avatar
Greg Rogers
I'll be following along, I am getting ready to do the same. Looks like you already replaced the rocker?
Old Jan 21, 2018 | 08:04 PM
brucelee's Avatar
brucelee
Haven't started on rockers. They are only rusted at each end about 2 inch worth. The worst part on the truck will be the roof drip rail area.
Old Jan 21, 2018 | 08:10 PM
brucelee's Avatar
brucelee
That's what I was thinking. I bought the patch panels about 8 years ago and a quick fit check tells me massaging will be required.
Old Jan 22, 2018 | 08:26 AM
wdglide's Avatar
wdglide
If it were me, I would remove the outer -- all the way around -- but only high enough to allow you access to your inner corner repair.
I would handle that large hole you cut as a separate job.
Mine was worse than yours, but I did a similar repair recently (see link in my signature).
Old Jan 22, 2018 | 08:54 AM
Indybeer's Avatar
Indybeer
My cab was worse than yours! Take a look at my albums....I took a lot of pics as I was doing the metal work on the cab. Might be of some help.
I had no metal working experience before I started, but really enjoyed doing it once I started.
Old Jan 22, 2018 | 02:51 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Dennis Carpenter & MidFifty both have new steel roofs for 56s. After buying 2 additional donor roofs and having them both sand blasted I’d have been money ahead to have bought the new steel roof.
Old Jan 22, 2018 | 09:13 PM
brucelee's Avatar
brucelee
Thanks all for advice. My Mig just broke (lowest setting won't work) once I get this repaired it's time to dive in and make some sparks
Old Jan 22, 2018 | 11:13 PM
jonnireb's Avatar
jonnireb
When you get to the point of tacking your corners in, let me suggest you hang a door(you can use visegrip clamps to hold it while you get everything aligned) that way you can see just what you've got in door gap and adjust accordingly.
Old Jan 23, 2018 | 02:33 PM
clintonvillian's Avatar
clintonvillian
I did the dumb thing.........and cut the whole corner off. Then tried to massage an entire new corner on. PITA. They still aren't right........Rear indent is wrong, door opening is wrong, curvature is wrong..
If I'd had mine to do over, I still would have removed a large chunk of the corner (very carefully). Replaced my inner corners, blasted the old outer corners, patched them up and welded them back in.
KirkF
Feb 19, 2021 06:34 PM
truckdog62563
Oct 18, 2016 06:00 PM
TxStang2010
Jun 15, 2014 03:25 PM
Lakotas53
Dec 1, 2010 06:34 AM
rcav8or
21
Jul 14, 2008 07:40 PM
