cab corner
Old Jun 15, 2014 | 03:07 PM
TxStang2010's Avatar
TxStang2010
cab corner
this is what my drivers cab corner looks like , the only bad spot to fix on the cab but all the patch panels I see only go up 10 inches from the bottom . I need a patch panel that goes up 16 inches ... prefer 18 inches if possible to get it 100 % . Is there anyone out there that makes this ?
right now that is a bit much metalworking for me , I would even consider used sheetmetal that is in better shape .
Old Jun 15, 2014 | 03:18 PM
mike k m's Avatar
mike k m
I would purchase 2 left side cab corners , just cut off what you need for the upper portion this should give you the proper curved edge you would need with very little fabrication.
Old Jun 15, 2014 | 03:25 PM
TxStang2010
now that sounds like a pretty good solution Mike , I thought of bending a piece of sheet metal but that area has a compound curve in it .
Using a piece of a second corner would keep the curvature ...... Great idea
march
Aug 25, 2017 07:28 PM
F-1
18
Apr 2, 2017 01:05 PM
turnrjr
Sep 12, 2012 01:06 PM
Lakotas53
Dec 1, 2010 06:34 AM
TxF100
Aug 30, 2008 11:14 PM
