2010 6.4 issue, need help!!
Me and my girfriend were coming back from dinner the other night when we stopped at a red light where a cummins was sitting, we attempted to race... I spooled up and hammered down at the light change and BAM!! Huge cloud of white smoke and the truck started making a tap noise and running rough, I pulled over and shut the truck off and noticed oil dripping from my oil pan gasket. I started the truck back up and limped it home,( less than a mile away), still blowing white smoke like crazy. The truck still starts but runs rough and after a minute of rrunning, the hard tap noise joins in again. Any suggestions??
If this person ever returns....
- was the truck tuned?
- white smoke is either a re-generation or water in the combustion chamber
- hard tap noise could be a lifter, or a bent push rod, or a failed rocker, or a caved in piston, or possibly a bearing
- how much oil was dripping?
Probably Time to start researching a new/used/refurbished motor and turbos. Also, new DPF.
Good luck.
jfaber
11-14-2009 10:34 AM
dallasford
08-19-2005 08:04 PM
