Installed duel fueler kit now truck is ant theft locked. - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.4L Power Stroke Diesel
Reload this Page >
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 01-29-2018, 10:16 PM
bigbubba87's Avatar
bigbubba87
bigbubba87 is offline
bigbubba87 is starting off with a positive reputation.
2007 F250 6.4 auto. H&S MINI MAX.
Last week a put larger injectors an elite diesel duel fueler kit and regulated return on a buddys truck. Got it done and when i tried to start it it turned over for 10 seconds and locked in anti theft mode. Now it will not do anything I have tried to reset the PATS system different ways i have found online and none of them work. Is there a way to completely disable the PATS system. The truck was factory dual alternator I had to removed the upper alternator to install the CP3. I just unplugged the wiring. Is there more to be done than just unhooking the harness when removing the alt. Would doing that have caused the PATS system to lock the truck. Any help is appreciated I dont know very much about the new fords.
Old 01-29-2018, 11:33 PM
DieselDenny
DieselDenny is offline
DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.
Only thing I can think of is the PCM or ECM isn't eyeballing the voltage from the alt harness that you removed.
Not quite sure how to rectify other than jumpers.
These things are very finicky when a body part is removed and not identified.
I'm thinkin that the primary voltage was from the one that was removed.........
Unsure, but be sure to post.
Denny
Old 01-29-2018, 11:37 PM
DieselDenny
Another afterthought, if I may.......lay the alt you removed off to the side and plug the harness in. See if it fires. Best jumper available.
Old 01-30-2018, 09:01 AM
bigbubba87's Avatar
bigbubba87
I tried to re install the second alt harness and hooked it to the alt but i cannot get the truck out of PATS mode to try it. I have read that if the truck cranked and then locked out it is something engine related causing the problem.
Old 01-30-2018, 10:47 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
speakerfritz has a good reputation on FTE.speakerfritz has a good reputation on FTE.
are you sure its a 6.4???
you said "2007 F250 6.4 auto"
Old 01-30-2018, 12:09 PM
bigbubba87's Avatar
bigbubba87
Sorry about that it is a 2008.
Old 01-31-2018, 06:48 PM
DieselDenny
Sorry, working alot.
Have you removed both negative cables for 20 minutes to set all the brains back in whatever order they should be in and try it again? Prior to any add on electronics>
Denny
Old 02-01-2018, 07:58 AM
bigbubba87's Avatar
bigbubba87
I put the factory HPFP harness back on and hooked the second alternator back up. I have let the truck sit for a day with battery's unhooked and it does not reset.
Old 02-01-2018, 08:12 AM
DieselDenny
Long shot!!!!
Do you have a keyfob? try and lock and unlock the doors with it first.
You might have to try to use a different ignition key.
My bosses exploder did this and it turned out that he had a "spare" key made that his system didn't recognize and it wouldn't start.
Like I said, Long shot.
Just trying to go with the least likely cause.
I've been searching the net, and can't find anything else to offer. Sorry
Do let us know what you conclude please.
Denny
Old 02-03-2018, 01:39 PM
bigbubba87's Avatar
bigbubba87
The key fob does nothing. There is only one set of keys for the truck. When the key is turned on the only thing that works on the truck is the radio, windows and lights. I have tried to connect with multiple scanners and none will work.
Old 02-03-2018, 01:50 PM
speakerfritz
E
buy 2 new key fobs on amazon for 10 bucks and follow programming instructions
Old 02-11-2018, 04:17 PM
DieselDenny
Where are you at on this Bub ?
csevans42
6.7L Power Stroke Diesel
04-01-2017 08:45 PM
Z-MAN
Bio-diesel, Propane & Alternative Diesel Engine Fuels
07-10-2008 04:02 PM
Chance_Thomas
05-22-2007 08:23 PM
hoyler1969
29
02-08-2007 04:54 PM
Quick Reply: Installed duel fueler kit now truck is ant theft locked.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
