Thick smoke!
Old Jun 19, 2007 | 07:06 PM
Goldenboy's Avatar
Goldenboy
Thick smoke!
1999 PSD, 7.3L. Had it about a year. Has 130K Km. (80K miles) Rumour is it was parked for a couple of years before I bought it.
Has been smoking excessively for a couple of months, but only occasionally, on start up or when cold. When I leave home, I idle only a few seconds, then drive. I go about 2 km, mostly downhill to the highway. Couple of weeks ago, it was smoking at the hwy junction and hesitated when I accellerated onto the hwy. Smoke seems to be okay when driving, maybe just harder to see as it is spread over a larger area??
Yesterday, I hauled our new (to us) camper trailer about 400km from dealer to home. It made a knocking sound about 30 km from home, so I pulled over, idled 2 minutes, then shut down and had a look. No oil leaking evident. Oil level okay. I started up and saw moderate smoke. Got home okay.
Today I started it up and huge clouds of dark grey smoke and a slight ticking noise! I shut down,and noted oil level was below add mark. I added 2L. Then drove a couple of hundred yards to where I usually park. (lots of smoke, ticking noise) /Checked the oil again; too full! I guess it was more the slope the truck was parked on. So I drained out the 2L. and oil level seems okay. I don't think it is using oil, but not 100% sure.
What to do? I have an appointment with Ford dealer thurs. Should I drive it in (20Km.) or have it towed?
Any idea what is going on? Injector o-rings? Any ideas apprecieated. Thanks [img][/img] [img]sick.gif[/img]
Old Jun 19, 2007 | 08:06 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thread moved to the 7.3 forum... I think you'll get lots more answers here
And Welcome to FTE!
Old Jun 19, 2007 | 08:41 PM
rbaker6336's Avatar
rbaker6336
smoke sounds like unburned fuel
maybe injector
Old Jun 19, 2007 | 09:18 PM
Goldenboy's Avatar
Goldenboy
Yes, I think it is unburned fuel. What is going on?
Old Jun 19, 2007 | 09:24 PM
medhvac's Avatar
medhvac
i really think unburnt fuel is black! but i could be wrong! bad injector=engine shaking loss of power! but more ppl may chime in!
rbaker6336's Avatar
rbaker6336
only 2 things can think of timing or injector with the ticking noise would think it would be an injector
Old Jun 19, 2007 | 09:25 PM
medhvac's Avatar
medhvac
o yes and welcome to fte!
Old Jun 19, 2007 | 09:27 PM
rbaker6336's Avatar
rbaker6336
you could be wrong if it is raw it is blueish white and stinks like hell
Old Jun 19, 2007 | 09:31 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Unburnt fuel vapor is white smoke. Blue smoke is oil, and black smoke is semi-burnt excessive fuel in the condition of not enough air to burn the fuel. So what color is the smoke?
Old Jun 19, 2007 | 09:33 PM
rbaker6336's Avatar
rbaker6336
wrong again
Old Jun 19, 2007 | 09:37 PM
John311t's Avatar
John311t
Hmm, im gonna give my 2 cents here. When my truck was having gelled fuel, and i was loosing pressure, it would blow white smoke, and knock really loud. Might want to see if you have enough fuel pressure, im talking LOW fuel pressure<10psi and it would start to get bad. Sounded like an old tractor.
Old Jun 19, 2007 | 09:44 PM
rbaker6336's Avatar
rbaker6336
low fuel will cause white smoke and cause injector tick
Old Jun 19, 2007 | 09:50 PM
PowerstrokeJunkie
Who is wrong again?
Old Jun 19, 2007 | 10:02 PM
rbaker6336's Avatar
rbaker6336
Who is wrong again?
you are white smoke is insufficiant fuel blue is unburned fuel
Old Jun 19, 2007 | 10:06 PM
John311t's Avatar
John311t
Wouldnt fuel vapor be low fuel condition?
