2010 6.4 issue, need help!! - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.4L Power Stroke Diesel
Reload this Page >
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 02-10-2018, 01:08 AM
dieselman102
dieselman102 is offline
dieselman102 is starting off with a positive reputation.
Me and my girfriend were coming back from dinner the other night when we stopped at a red light where a cummins was sitting, we attempted to race... I spooled up and hammered down at the light change and BAM!! Huge cloud of white smoke and the truck started making a tap noise and running rough, I pulled over and shut the truck off and noticed oil dripping from my oil pan gasket. I started the truck back up and limped it home,( less than a mile away), still blowing white smoke like crazy. The truck still starts but runs rough and after a minute of rrunning, the hard tap noise joins in again. Any suggestions??
Old 02-10-2018, 08:25 AM
DogRidesInBack's Avatar
DogRidesInBack
DogRidesInBack is offline
DogRidesInBack is gaining momentum as a positive member of FTE.DogRidesInBack is gaining momentum as a positive member of FTE.
Ouch...
Any coolant in the oil or oil in the coolant?
Old 02-10-2018, 10:18 AM
Tom's Avatar
Tom
Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
I'm moving this one to the 6.4L forum, you should get a better response down there. Welcome to FTE by the way...
Just out of curiosity, was the truck tuned? Sounds to me like you've got a very expensive problem.
Old 02-10-2018, 10:41 AM
Copper.Farm's Avatar
Copper.Farm
Copper.Farm is offline
Copper.Farm is gaining momentum as a positive member of FTE.Copper.Farm is gaining momentum as a positive member of FTE.
If this person ever returns....
- was the truck tuned?
- white smoke is either a re-generation or water in the combustion chamber
- hard tap noise could be a lifter, or a bent push rod, or a failed rocker, or a caved in piston, or possibly a bearing
- how much oil was dripping?
Old 02-10-2018, 01:57 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is online now
speakerfritz has a good reputation on FTE.speakerfritz has a good reputation on FTE.
pull the codes and see if there are any contribution balance codes.
Old 02-10-2018, 02:53 PM
dieselman102
the truck is not tuned nor deleted
Old 02-10-2018, 02:56 PM
dieselman102
truck is not tuned, I'm pulling a cylinder 8 misfire code, and alot of oil is dripping as long as the truck is running it builds back pressure and pushed the oil through the gasket of the oil pan
Old 02-10-2018, 03:06 PM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
CampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputationCampSpringsJohn has a superb reputation
Don't believe you'll find a code for blown head gasket or a hole in a piston.
Old 02-10-2018, 03:23 PM
Copper.Farm
You might want to pull the glow plugs and do a compression test on all cylinders. Also, if you remove the oil filler cap while the motor is running you’ll probably feel the flutter of presure - which is either a hole or crack in a piston.
Probably Time to start researching a new/used/refurbished motor and turbos. Also, new DPF.
Good luck.
Torky2
Escape & Escape Hybrid
10-28-2016 10:17 AM
Pheasanthunter66
1999 to 2016 Super Duty
07-04-2016 02:23 PM
bookpile
07-23-2012 09:40 AM
zoumm
09-09-2011 06:51 PM
tri-sbr
2009 - 2014 F150
02-05-2010 10:05 PM
Quick Reply: 2010 6.4 issue, need help!!
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
