Mystery wire
Old Jan 20, 2018 | 05:41 AM
Texasknowhow's Avatar
Texasknowhow
Mystery wire
Guys, baselining a 1997 F250 w the 7.3. Found a small wire with a 90 deg cap on it near the fuel filter. Can anyone identify what it’s for?
I’m uploading a quick video of it here:
https://www.dropbox.com/s/dxlmogb6lt...%20AM.mov?dl=0
Thanks in advance! Clay
Old Jan 20, 2018 | 07:48 AM
helifixer's Avatar
helifixer
Fuel filter restriction switch, (ford calls it a vacuum switch) yours has been removed, it is a leak point and quite expensive for what it is.
also your boot from the driver side valve cover to the turbo (orange boot) is a recalled boot and updated with a black one that doesn't tear as easy foding yout turbo.
Old Jan 20, 2018 | 07:53 AM
helifixer's Avatar
helifixer
that pic is one of my '97's it hasn't started leaking "yet" that is why the sensor is still there. when it starts leaking sensor will be removed and an 1/8" pipe plug installed. I heat shrink the end of the wire and tie it back to the harness when I do that.
Old Jan 21, 2018 | 01:12 AM
Texasknowhow
Thanks for that answer. Makes total sense now. So should I ask for the updated turbo hose at a Ford Dealership? Mine is torn under the hose clamp on the turbo end. As I detail this new (to us) truck I will probably have additional questions. Another loose wire was found wrapped around the trans x-member - it fit a plug up high on the Driver’s side of the transmission. I’m thinking either reverse light switch or Neutral Safety Switch...??? I hooked it back up, but won’t probably fire it up until sometime tomorrow to see if I have something new working or not haha.
Thanks again.
Old Jan 21, 2018 | 07:45 AM
Shawn MacAnanny's Avatar
Shawn MacAnanny
I had the same issue with my orange hose. I got the one Riff Raff makes. I had a terrible time getting it to fit on but its high quality.
Riffraff Diesel 94-97 Turbo Intake Boot - Ford 7.3L
Old Jan 21, 2018 | 11:09 PM
madpogue's Avatar
madpogue
Automatic or manual transmission? How many terminals on that second connector you found?
Old Jan 22, 2018 | 03:48 AM
Texasknowhow
It’s the manual 5 speed. Two conductors on the wire/connector.
Old Jan 22, 2018 | 05:44 AM
madpogue's Avatar
madpogue
That's the reverse light switch. There's no neutral safety switch.
Old Jan 22, 2018 | 08:40 AM
Texasknowhow
Okay cool. I’ll need that to get my inspection for sure!
Old Jan 22, 2018 | 09:15 AM
farmert's Avatar
farmert
If it fits that plug, and one of the wires is purple and the other is black, they are for the reverse lights. Go with the Riff Raff turbo hose, the updated one from ford comes as a kit that includes the metal piece that the crankcase breather tube hooks into that you don't really need to replace, but the new turbo hose won't fit the old metal tube. Plus it is a lot cheaper than the Ford kit.
Old Jan 22, 2018 | 09:21 AM
Texasknowhow
Thanks Farmert, I believe that is the wire. Also I’ll look into the RiffRaff hose. Thanks man.
superduty4x4
15
Sep 6, 2021 10:50 PM
ericbskis
Oct 7, 2014 11:45 AM
KH85
Aug 5, 2011 04:37 PM
oldgameandfishdiesel
Jan 12, 2009 05:23 PM
Ed in Maine
Nov 26, 2007 01:33 PM
