AFE intake replacement filter
Old Jan 21, 2018 | 10:18 AM
njo's Avatar
njo
Hello, I have a afe intake on my 94 F250, is there an alternative like NAPA where I can get a filter that would fit on the tube and in the housing? Or do I have to spend 80 bucks on another afe filter? Thanks a lot.
Old Jan 21, 2018 | 11:38 AM
oldbird1965's Avatar
oldbird1965
Just clean it and oil it and put it back in. I'm not sure if the napa 6637 would fit the housing but my guess is YES?
Old Jan 21, 2018 | 10:04 PM
pilgrimbizket's Avatar
pilgrimbizket
Find a small 1 gallon bucket, put a generous amount of simple green and one scoop of oxy clean detergent(for clothes) add water. Let that bad boy sit, genoursly wash out 2 or 3 times.
Let it dry, spray w are oil.
Filters look brand new w this method
Old Jan 21, 2018 | 10:39 PM
oldbird1965
That's interesting! I've just been using the cleaning stuff that comes in the kit from AFE, then the oil. It doesn't come out looking brand new though. Is your method harmful to the filter?
Old Jan 21, 2018 | 10:51 PM
pilgrimbizket
My filter is going strong, can't say for sure but my bro does the same with kn intakes.
I seen it on you tube, and have done it 5 times now. They come out brand new. I've done it w/o oxy clean too, works great w just simple green as well
Old Jan 22, 2018 | 08:26 AM
nolszewski's Avatar
nolszewski
I ask about replacing the filter because after I cleaned mine with soap was water from the inside out, I noticed a development of dirt on the inside of the intake tube. I did not see this before when I pulled the filter off to clean it. I driven it around 300 mi up toe pulling the filter again. My first thought is the filter is as, has a lot of creases in it. I know the sleeve is right around the tube so no leaks. Thoughts? I was just going to play it safe and get a new filter
Old Jan 22, 2018 | 12:34 PM
pilgrimbizket
that's intriguing, did u purchase the truck w the filter already installed?
possibly previous owner didn't spray it right one time.
I'd prob just buy a new one to be safe myself
Old Jan 22, 2018 | 01:13 PM
nolszewski's Avatar
nolszewski
The truck had the afe components when I got it. I believe the filter element was an oil less one because it was not blue based on what I’ve seen online. I say this because the owner used filter oil on it so it’s now a brownish color. I didn’t re oil it when I cleaned it so I don’t know if that affected it. Also I don’t know the consequences on oiling a non oil filter. I’ll bebuying a new filter.
Old Jan 22, 2018 | 01:52 PM
pilgrimbizket
Well u have dirt in the intake tube bedcause u didn't re oil it most likely. U should post a pic of ur setup.
hold on though, their is also a gold/yellow oil and mine turns brown when dirty it once even was reddish brown.
I bet it was the yellow one. I cleaned mine 2 months ago and it looks reddish brown right now. But I've put at least 2k on my truck on dirt roads alone.
Old Jan 22, 2018 | 01:57 PM
nolszewski's Avatar
nolszewski
That makes more sense thanks. I’m still going to pick up a new filter because mine is crushed a bit and has a lot of caked dirt in the inner folds. I’ll be sure to oil the new one
River19
Oct 7, 2010 12:29 PM
SuperDutyScaler
Sep 14, 2010 10:05 AM
Fire85
Aug 27, 2007 04:29 PM
UGA33
Jul 18, 2007 10:16 AM
Smokin'
28
Dec 27, 2006 02:38 AM
