EBPV Sensor Location
Old Aug 5, 2011 | 01:53 PM
KH85's Avatar
KH85
Im in the process of doing my EBPV override switch an wanted to be sure which is the correct conector to cutt. I know its just two wire connector facing forward but is it the one on the y intake part or the one behind that on the turbo pedestool that looks harder to get to?
Old Aug 5, 2011 | 02:00 PM
hotroddsl's Avatar
hotroddsl
It's the one way back on the turbo pedestal, it's not so hard to get to if you remove the passenger side CAC tube. Hope this helps.
Jim...& fat Monty
Old Aug 5, 2011 | 03:23 PM
KH85's Avatar
KH85
Thanks man I got it out an tested and got the 12v flashing signal I was looking for!
I have another stupid question.....the switches that I bought have three terminals one says ground, one says power, and says ACC.
Its only a two postion switch so what is the ACC one in the middle for? If I just use the power and ground will the switch to work properly?
Old Aug 5, 2011 | 03:27 PM
KH85's Avatar
KH85
Is it accesory?.....that would make sense.
So if there is no accesory to the switch it will still do what I need it to do correct?
Old Aug 5, 2011 | 03:31 PM
hotroddsl's Avatar
hotroddsl
Acc is usually if the switch has a lighted indicator if that's the case it requires 12v to that terminal for the light to work! Why are you switching the EBPV? Exhaust brake?
Jim...& fat Monty
Old Aug 5, 2011 | 04:33 PM
KH85's Avatar
KH85
U got it. Just got it all hooked up an it works good. Havent drove it yet but it comes on an off with the switch.
On to the torque converter lockup.
Old Aug 5, 2011 | 04:37 PM
hotroddsl's Avatar
hotroddsl
It's a nice easy mod and actually works pretty darn good!
Ranger1F150
May 30, 2008 07:19 PM
wmiller
Feb 25, 2008 07:45 PM
aocabrown
Dec 28, 2007 02:27 AM
79f-250custom
Nov 16, 2007 02:07 PM
TopThis8899
27
Sep 5, 2007 10:16 PM
