GEM MODULE!!!!!!!
Old Jan 20, 2018 | 03:04 AM
StrokinHer01's Avatar
StrokinHer01
GEM MODULE!!!!!!!
I CANNOT find anything on 2001 7.3 f250 gem removal except on expeditions and 150’s... what is the easiest way to remove it,open it up to see if it’s corroded and reinstall it??? HELP!
Old Jan 20, 2018 | 06:13 AM
tjc transport's Avatar
tjc transport
i ain't rite
depends on what year truck you are dealing with. i believe 01 was the last year for the GEM module.
Old Jan 20, 2018 | 07:44 AM
StrokinHer01
2001 my luck
Old Jan 20, 2018 | 07:48 AM
Walleye Hunter's Avatar
Walleye Hunter
Isn't the GEM piggybacked to the rear of the under dash fuse box?
Old Jan 20, 2018 | 07:53 AM
StrokinHer01
Ya but I’ve seen only pictures of bringing it up through that headlight switch hole since the gem is right below it . Other way is drop it straight down
Old Jan 20, 2018 | 08:31 AM
tjc transport
i ain't rite
yup, GEM is on the backside of the in cab fuse box.
i don't remember if it just unplugs, or needs to be unbolted to unplug though.
what issues are you having that you suspect a bad GEM?
Old Jan 20, 2018 | 08:59 AM
timmyboy76's Avatar
timmyboy76
Striker... Remove/unplug everything so that you can get the bezel(dash ring) out. Then, remove the 4 8mm bolts holding the cluster. Lift it out and unplug the 3 connectors. From there, you can have dinner on that damn module
Old Jan 20, 2018 | 03:59 PM
StrokinHer01
The 4x4 doesn’t work
Old Jan 20, 2018 | 04:45 PM
tjc transport
i ain't rite
that could be bad transfer case motor, bad front locking hubs, or a vacuum leak if it is ESOF. those are the three primary reasons for no 4X4 with ESOF
Old Jan 21, 2018 | 12:48 AM
StrokinHer01
The motor works cause I have it wired to a toggle switch and that’s how I use four wheel drive but the lights don’t come on on the dash when it’s in.. I did a manual hub swap
Old Jan 21, 2018 | 08:30 AM
FarmingF250's Avatar
FarmingF250
On my 2000 the GEM was behind the main fuse box in the cab, you have to remove the fuse box and the GEM is on the back. Biggest head ache getting main fuse box out is unscrewing the bolts holding the cable connectors to the box, then fishing the box out into the drivers footwell from the pedals etc.
Old Jan 21, 2018 | 04:10 PM
jimjokjv's Avatar
jimjokjv
Try this link: https://www.ford-trucks.com/forums/1...ug-wiring.html
lauraj
Nov 13, 2014 09:42 AM
Meg719
Apr 13, 2010 06:56 AM
Rollinon40's
1997 - 2003 F150
Dec 2, 2008 08:47 AM
encourager
Jul 8, 2007 10:36 PM
15FordMustange
1997 - 2003 F150
Dec 21, 2006 03:21 PM
