Sponsored by: Auxito
Can Anybody Help Me ??
Old Dec 21, 2006 | 02:55 PM
15FordMustange's Avatar
15FordMustange
We Have A 1997 Ford 4X2 And Are Having Alot Of Problems.
Passenger Side Airbag Light Flickers And Drains Battery Overnight,
My Blower Motor Stays On With Key Out Off Ignition, Also Sometimes
Speedometer Does Not Work. I Have A Friend That Has A Garage And He
Told Me Something About A GEM Module Or Some Kind Of Module (with
possible water leak) But He Wasn't That Sure About It Or What To Do.
Can Anybody Help Me
Old Dec 21, 2006 | 03:03 PM
KingRanchMan02's Avatar
KingRanchMan02
Welcome to FTE 15Ford.
Have the windshield resealed first. The General Electronics Module is attached to the back of the fuse panel under the dash. Water in the GEM is causing a lot of your problems. Depending on how long water has been getting into the GEM, will determine if you can simply take it out and let it dry out or if it will have to be replaced. Many times the GEM and the fuse panel have to be replaced due to excess corrosion.
Good luck!
Old Dec 21, 2006 | 03:21 PM
15FordMustange
Thank You
Thank You For The Information
