Need help finding a part
Old Jan 19, 2018 | 08:51 PM
scoham64f100's Avatar
scoham64f100
I have a 64 F100 Automatic that has popped out of park a couple times. I've looked on four suppliers sites with no luck in finding the part available. Is it a dealer stock item?
Old Jan 20, 2018 | 12:22 AM
TA455HO's Avatar
TA455HO
Lead Gopher
C1TT-7A216-A | RearCounter.com | 6 found at 2 sellers
Chad
Old Jan 20, 2018 | 02:33 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C1TT-7A216-A .. Transmission Control Selector Position Insert / Obsolete
1961/64 F100/250 with FX Cruise-O-Matic.
In addition to the above, GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959.
Shown as 7A216 in pic:
Old Jan 20, 2018 | 02:42 AM
scoham64f100
Thanks a lot! I'll call and see if I can get one first thing in the morning. Thanks again!
Old Jan 20, 2018 | 02:48 AM
NumberDummy
I don't know how many of the sources will be open on Saturday.
Old Jan 20, 2018 | 09:38 PM
scoham64f100
1964 Falcon Shift Detent
Found a shift detent that matched the one on the truck. This was the only place I could find one in stock with a web site ready to order, so I took a chance and ordered it. Felt pretty confident it'll work.
https://www.dearbornclassics.com/col...lane-1964.html
Old Jan 20, 2018 | 09:59 PM
NumberDummy
It will not!
WRONG PART! This is for a 1964 Fairlane 289/C4, the Ford part number is: C4OZ-7A216-A
The one you need is for a 1961/64 F100/250 2WD w/FX Cruise-O-Matic.
Post #2: Chad gave you the applications/sources and Ford part number (C1TT-7A216-A) for the correct detent. I added further info in post #3.
So why in the hell would you assume a 1964 Fairlane detent would work?
And...besides the detent, the '64 Fairlane uses a different upper flange than 1961/64 F100/250 2WD
Old Jan 21, 2018 | 01:28 PM
scoham64f100
This is the 64 Falcon detent
This is the one that came out of my truck.
I think they are the same part. I'll let you know if I'm wrong when it gets here.
Old Jan 21, 2018 | 02:31 PM
NumberDummy
The one you bought is for a 1964 Fairlane w/a 289/C4 (C4OZ-7A216-A). 1964 Falcon 260 V8 came with the 2 speed Ford-O-Matic.
The one you need is for a 1961/64 F100/250 2WD with FX Cruise-O-Matic (C1TT-7A216-A).
Since the part numbers are different, the one you bought is incorrect!
There's a gazillion different detents, all look similar, but that doesn't mean they are all the same.
Old Jan 21, 2018 | 02:51 PM
scoham64f100
My bad, I meant Fairlane as listed in the part link.
Old Jan 25, 2018 | 07:00 PM
scoham64f100
Got it in the mail today and installed it. Works great and is thicker and more heavy duty than the one I replaced. It should last my lifetime.
http://www.facebook.com/scott.hammons.18/videos/pcb.1000350573452079/1000350460118757/?type=3&theater
Old Jan 25, 2018 | 07:06 PM
scoham64f100
Got this breaker in the mail today also. May get it installed tomorrow after the annual VA appointment. This will be the trucks longest drive so far. I expect weak parts to fail in the near future the more I drive it, so I'll go as prepared as possible.
Markybe
Nov 6, 2018 05:08 PM
Trent_Lalonde
Nov 27, 2014 01:31 PM
cheddar89
Missouri Chapter
17
May 18, 2012 07:32 AM
my69
13
Jul 23, 2011 12:28 PM
donjamer
Massachusetts Chapter
Oct 18, 2010 09:50 PM
