EBPV questions
Old Jan 19, 2018 | 08:46 AM
B-Rad88's Avatar
B-Rad88
Veteran: Navy
EBPV questions
So now that I'm ready to get things back together in my truck, I'm wanting to get the turbo and everything else back in after work today. I have a bypassed exhaust fitting where thd butterfly flap used to be, with freeze plug in it and it's been ceramic coated, along with a ceramic coated 1.0 housing. I would like to remove the EBPV piece from the pedestal but not sure if it's as easy as I just pull the snap ring off and then pull the stuff out, put that brass colored cap back in with the snap ring, and then plug that tiny hole on the other side. Are there oil passages that I will have issues with if I just gut it and plug it? Ive read that quite a few people have done just that. Worst case scenario I will just leave it with the rod sticking out and it's not hooked up to anything. That's how it was in my truck when I started pulling everything a few weeks ago.
Old Jan 19, 2018 | 09:27 AM
knottyrope's Avatar
knottyrope
there is an oil passage to block with a plug after you tap it or tig weld it
Old Jan 20, 2018 | 08:48 AM
fordpride's Avatar
fordpride
Are you can cut and weld it.
It makes pulling and installing the turbo a lot easier
https://www.ford-trucks.com/forums/1...-pedestal.html
20powerstroke02
55
Oct 31, 2016 06:38 AM
bubba_3711
Feb 8, 2013 03:19 PM
plgebbia
Jul 13, 2010 10:15 PM
schmity
23
Jan 25, 2008 08:14 PM
RubberDuck
Aug 15, 2006 05:24 PM
