starter solenoid problems?
Old Jan 18, 2018 | 11:05 PM
FORD-or-Die's Avatar
FORD-or-Die
[95 7.3] Hey guys was having problems with no crank starts would have power light etc no crank though, thought my starter solenoid mounted on the passenger fender was shot b/c i would jump it from the 2 terminals just fine. replaced solenoid now same issue seems to be incurring(not as frequently though). where should i go from here am i not getting my small current through from the ignition or what?
Old Jan 19, 2018 | 02:36 AM
madpogue's Avatar
madpogue
Automatic or manual transmission?
Old Jan 19, 2018 | 05:49 PM
FORD-or-Die
automatic e4od 4x4 on the fly
Old Jan 20, 2018 | 06:08 AM
tjc transport's Avatar
tjc transport
i ain't rite
it could be a bad fender relay, or an improperly adjusted neutral safety switch.
next time it does it, try pushing the shifter up to park, or pull it down to neutral with the key in start and see if it makes any difference.
starter relays are now chinese crap, and sometimes you need to put 5-6 on to find a decent one.
Old Jan 20, 2018 | 09:03 AM
madpogue's Avatar
madpogue
Actually, for the money, if you need a starter relay I'd adapt a Western Plow 56131K, the one often used as a GP relay. Only "mod" you'd need to do is make a short ground wire with a ring terminal on each end. Attach one end to the second small terminal on the relay, and the other to the mounting screw. That'll outlast a case of the cheap ones.
wrdabney
Mar 13, 2019 04:15 PM
cadunkle
23
Mar 14, 2018 01:21 PM
fluidp
Jul 8, 2014 08:26 PM
f1001969mike
1978 - 1996 Big Bronco
Jan 27, 2013 12:03 PM
BigDude97
20
Sep 15, 2010 06:10 AM
