1986 E 350 Battery Cables?
Old Jan 17, 2018 | 08:54 PM
Surf4321's Avatar
Surf4321
Really need some new battery cables on my 86 van. The passenger positive cable going down under the van is almost bare at the terminal. Just have some electrical tape over it now. Ive tried searching for the cable but can't find a place that sells them. Autozone shows they sell them but shows them for $10-$15 and I can't see how that could be the right cable for that cheap.
Any suggestions for where I can get the right cables?
Old Jan 17, 2018 | 09:54 PM
madpogue's Avatar
madpogue
Hmm, according to RockAuto, the trucks and vans use the same positive cable assembly, which I wonder about. Your other battery is down on the frame somewhere, right? Hmm, maybe the same cable does fit/work. Anyway, it's Standard Motor Products, A11600HP , also available on Amazon.
Old Jan 17, 2018 | 10:10 PM
Tedster9's Avatar
Tedster9
If you know the length and ring terminal size, just about anybody can make what you want, online vendors or maybe local. Welding supply co., even eBay. $20 or $30 should get you all hooked up, with good stuff and solid copper tin coated terminals.
Old Jan 18, 2018 | 12:09 AM
genscripter's Avatar
genscripter
On the vans, the two batteries up on top. Assuming the starter is the same distance from the passenger side battery compared to trucks and vans, I would think the cables are the same as the truck.
Old Jan 18, 2018 | 06:57 PM
MR KROGOTH's Avatar
MR KROGOTH
https://www.oreillyauto.com/detail/s...993/ford/f-250
Cheapest thing and easiest thing.
Old Jan 18, 2018 | 08:32 PM
madpogue's Avatar
madpogue
"Cheapest" meaning $12 MORE than a name brand (Standard Motor Products) at Amazon.
Old Jan 19, 2018 | 10:31 AM
DrCharles's Avatar
DrCharles
I just searched Amazon for replacement battery cables ('93 F250 7.3) and only see a BWD positive harness (for MORE than O'Reilly) and two Standard Products negative cables.
Maybe it's different for the E350? Can you please provide the part number?
Old Jan 19, 2018 | 01:41 PM
madpogue's Avatar
madpogue
According to RockAuto, it's the same part, Standard Motor Products, A11600HP, even for the '93.
Old Jan 19, 2018 | 04:39 PM
DrCharles's Avatar
DrCharles
Thanks! For some reason the idiotic search engine at Amazon shows it as "This does NOT fit your vehicle" which is why it didn't come up under replacement cables. Even though it obviously does!
You saved me some money when it's time for a replacement
snaponprofile
May 7, 2011 08:43 PM
Pest007
Sep 8, 2009 10:57 AM
basfire
Dec 5, 2008 10:39 PM
whitesdford
Sep 11, 2007 10:03 PM
stupidjet
Feb 4, 2005 06:32 PM
