Constant ABS issue- C1234
Old Jan 17, 2018 | 03:55 PM
Millinex's Avatar
Millinex
ABS light constantly on. I'm used to sensors going out on these.
I replaced the sensor. 3 times now. First time I used a brand new aftermarket sensor. No change. second time, I used an OEM used sensor to test with, again, no change.
I swapped the sensors from the 2 front wheels. Code did NOT follow the sensor.
When I clear the codes, turn the key and start the vehicle, as long as I do not move, the code does not come on.
I unplug the sensor- the ABS light illuminates. Same code, C1234. This leads me to believe the wiring itself is not bad or at fault.
I swapped both front hubs between each other thinking maybe I had a hub going bad. No change. I swapped the front hub with a few other hubs out of other trucks I have here (none of which have ABS light on ever), no change.
At this point- I'm at a little bit of a loss. Other than pulling the cluster and pulling the light- I'm out of ideas, and tired of pulling this front end apart over and over.
Any thoughts?
Old Jan 23, 2018 | 11:56 AM
Turfzilla's Avatar
Turfzilla
Sorry not much help here, but my ABS light has been on for several years and many miles later have still seen no ill effects. Carry-on.
Old Jan 23, 2018 | 12:50 PM
roadrnnr's Avatar
roadrnnr
Have you considered the wiring may be the issue? Check for any broken insulation etc.
Old Jan 23, 2018 | 02:01 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
This is from the 01 manual...might be of help.
fordboy67
Jan 25, 2017 10:03 AM
Garrthomp823
Sep 8, 2014 07:58 PM
snakedoc
Jun 24, 2011 04:15 PM
billcollector
Feb 5, 2010 02:33 PM
DieselJr
Oct 17, 2008 09:35 AM
