Radio does not work
Old Jan 17, 2018 | 03:21 PM
Fords'nFire's Avatar
Fords'nFire
Radio does not work
The other day I wrapped a piece of wire around the antenna stub to see if it improved the reception. It did not and now the radio does not work at all, no static-nothing. The fuse is good and there is power to the green plug. Now the wire did touch the cab for a bit. Did i somehow fry the radio through the antenna
Old Jan 17, 2018 | 04:06 PM
Canus's Avatar
Canus
What you did had nothing to do with your radio not working.
Old Jan 17, 2018 | 04:54 PM
HIO Silver's Avatar
HIO Silver
The radio/head unit in my Ferrari 360 doesn't work either... weak reception, static, funky controls, it thinks it's shortwave or something...
Oh well.
Old Jan 18, 2018 | 07:03 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
No you did not fry anything. Sounds like you radio itself (internally) has just died. Especially if you checked for a good fuse and power to the green plug.
"The OEM radio was powered by a GREEN 2-terminal pigtail. YELLOW with a BLACK stripe is switched power, BLUE with RED stripe is dash illumination. Do not mistake the BLUE with RED stripe wire for ground. The OEM radio grounded through its mounting chassis. The speakers were connected over a separate pigtail."
Fuse box diagram: https://www.ford-trucks.com/forums/1...l#post14696846
"For OEM radio help, the guy to use is in Scottsbluff Nebraska. His name is Gene Cochran, and he works out of his house. He's a crusty old codger, but does some tremendous work. While he had the radio apart, he updated some of the internals and cleaned the heck out of everything. My total bill was $25! His number is 308 632-2520 (I checked with him at the time I collected my stereo, and he was OK with giving his number out)
He also lined me out on the manner in which the old radios were wired (mine at least). The speakers are in series meaning positive from radio to positive on speaker #1, negative from that speaker goes to positive on speaker #2. Negative from Speaker #2 goes to Negative on stereo. Now the stock stereo rocks as loud as the little 5 1/2 speakers can handle!!!
While it's there you might see if he'll wire in an aux input jack. I had it done with mine, and it allows me to run my I-pod through it. Basically when the I-pod is connected it becomes the antenna source. Cost in parts was under $5. I set mine on a 12" extension so I could just drill a small hole in the dash by the ashtray, which I'm turning into a covert charging / storage station for my phone and I-pod. won't cost much more."
Old Jan 18, 2018 | 08:17 AM
Fords'nFire
Thanks I didn't think it had anything to do with it. I'll probably replace it with a newer unit. For now I'll just enjoy the wind and exhaust noise.
Old Jan 18, 2018 | 01:23 PM
77&79F250's Avatar
77&79F250
Options that fit back in the same hole. Truck Parts and Truck Accessories
1973-1979 Ford Truck Radio USA-230: Classic Car Stereos
https://www.macsautoparts.com/ford_t...630-model.html
Buy a bracket...http://www.ncspecialties.com/shop/dinbracket/index.htm
NOT me and not the correct way to remove you headlight ****.. but this will get you there.
RileyCarroll
Nov 23, 2016 06:50 AM
tsuess
Nov 9, 2014 09:43 AM
Idlewild24
Jun 4, 2014 01:56 PM
9wire
Feb 16, 2013 07:52 PM
cujo8
Mar 2, 2008 05:17 PM
