Dead radio
Old Jun 3, 2014 | 09:25 PM
Idlewild24's Avatar
Idlewild24
Dead radio
I've got the stock radio out of my pickup, and it seems pretty dead. I would like to see if I can fix it up so I can keep it the truck original. Any ideas of where I should start?
Old Jun 3, 2014 | 10:33 PM
co425's Avatar
co425
Have you checked the fuse? Also make sure it's actually hooked up. I.E speaker not blown and present. Also make sure the antenna is hooked to it, and doesn't have a short in it with a continuity tester.
Old Jun 4, 2014 | 07:10 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Like co425 said, the place to start is check the fuse.
On these radios, the fuse isn't in the fuse block, it's inline, near the radio/
Old Jun 4, 2014 | 08:14 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Does the radio light/lamp even come on? Ck #2the top R/H fuse. Also Ck the wiring and look for an inline fuse.
The OEM radio was powered by a GREEN 2-terminal pigtail. YELLOW with a BLACK stripe is switched power, BLUE with RED stripe is dash illumination. Do not mistake the BLUE with RED stripe wire for ground. The OEM radio grounded through its mounting chassis. The speakers were connected over a separate pigtail.
Ok I looked behind the glovebox and found a connection the goes off the green and yellow. GREEN with YELLOW stripe wiring is hot-at-all-times power for the courtesy lamp circuit. Use that. There is a 3-connector pigtail behind the glovebox (which also goes on to power the cigarette lighter).
It's not the stock radio wire because the stock radio didn't need hot-at-all-times power (EXCEPT the factory digital AM radio for clock memory).
solid black--power
blue with red stripe--dial light
black with gray dashes--ground
orange with green dashes--right speaker
white with green dashes--left speaker
If its the radio internally, here is a good place to get it repaired and a IPOD connection installed.
The guy I used is in Scottsbluff Nebraska. His name is Gene Cochran, and he works out of his house. He's a crusty old codger, but does some tremendous work. While he had the radio apart, he updated some of the internals and cleaned the heck out of everything. My total bill was $25! His number is 308 632-2520 (I checked with him at the time I collected my stereo, and he was OK with giving his number out) He also lined me out on the manner in which the old radios were wired (mine at least). The speakers are in series meaning positive from radio to positive on speaker #1, negative from that speaker goes to positive on speaker #2. Negative from Speaker #2 goes to Negative on stereo. Now the stock stereo rocks as loud as the little 51/2 speakers can handle!!!
While it's there you might see if he'll wire in an aux input jack. I had it done with mine, and it allows me to run my I-pod through it. Basically when the I-pod is connected it becomes the antenna source. Cost in parts was under $5. I set mine on a 12" extension so I could just drill a small hole in the dash by the ashtray, which I'm turning into a covert charging / storage station for my phone and I-pod. won't cost much more.
Old Jun 4, 2014 | 01:56 PM
fmc400's Avatar
fmc400
MSEE
What does dead mean? No audio output at all?
JefflovesF250s
Apr 2, 2019 09:17 PM
Fords'nFire
Jan 18, 2018 01:23 PM
Riskit
Sep 15, 2015 11:24 PM
tsuess
Nov 9, 2014 09:43 AM
CropDusterMan
Jan 19, 2012 08:25 AM
