Waterpump?
Old Jan 22, 2018 | 08:53 PM
Per4mance's Avatar
Per4mance
Love it when a plan comes together. Pulled the pump out tonight. Just as I thought, impeller is cracked and spinning on the shaft. I have no idea how this happened. I'm going to pull the lower hose to make sure that there's nothing in to make it jamb and crack. It's not the stock pump so who knows what brand it is. I'll bet it's from the same parts house that the glow plugs came from. They said made in Ireland on them.
If you look real carefully you can see the crack on the left.
Old Jan 22, 2018 | 09:33 PM
TooManyToys.'s Avatar
TooManyToys.
Bill, from the internet pictures I've seen that's typical.
Old Jan 22, 2018 | 09:35 PM
Per4mance's Avatar
Per4mance
It's a 90mm pump. Didn't take long to get out but I'm suffering right now. Getting old sucks
Old Jan 23, 2018 | 08:55 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Glad you got it figured out, metal impeller time for you.
Old Jan 23, 2018 | 11:26 AM
diesel_dan's Avatar
diesel_dan
Hard to tell from the pic, but looks like the crack is on the other side too. Is that normal for that much wear on the vanes?, or is it from the Impeller being able to move back and forth on the shaft once the crack started... Almost looks like it seized in there...
Well in any case you have your answer...
Scott
Old Jan 23, 2018 | 05:36 PM
Yahiko's Avatar
Yahiko
How did the face of the cover look where the impeller might of rubbed?
Old Jan 23, 2018 | 06:44 PM
jsm180's Avatar
jsm180
Better than it would have looked if it was a metal impeller. My original was still good @ 160k mi but I replaced it any way with another Motorcraft.
Old Jan 23, 2018 | 08:04 PM
Per4mance's Avatar
Per4mance
I'll take pics tomorrow in the daylight. I should of had the kid do it but you know how that goes. I'm suffering today.
Old Jan 23, 2018 | 09:48 PM
Yahiko's Avatar
Yahiko
Bill take care of your self first and just have the young one do it.
Old Jan 24, 2018 | 05:51 AM
xaviar's Avatar
xaviar
[QUOTE=Yahiko;17748236]Bill take care of your self first and just have the young one do
X2 on that!
Old Jan 24, 2018 | 10:33 AM
Per4mance's Avatar
Per4mance
This isn't the greatest pic and the coolant looks green for some reason. It's got G05 in it and I flushed when I first got it.
Old Jan 24, 2018 | 01:07 PM
Yahiko's Avatar
Yahiko
Wow it's got a big hole in the back.
But other than that one big hole the only thing I see looks to be light scuffing.
Old Jan 24, 2018 | 03:00 PM
  #28
Per4mance's Avatar
Per4mance
It isn't that bad as scuffing goes. I've never seen G05 be green in pictures. You look at it in the daylight it's yellowish. I got to go down to XDP and pick up the pump and start re assembly.
Old Jan 24, 2018 | 03:31 PM
  #29
Yahiko's Avatar
Yahiko
More than likely the camera filter is blocking out some of the colors and turning it green.
Old Jan 24, 2018 | 04:31 PM
  #30
Per4mance's Avatar
Per4mance
Something had happened to the phone camera when I was down in FLA. Thing has been right since. I'm almost due for a new phone.
