blend door thumping in dash
Old Jan 16, 2018 | 06:19 PM
dewjr's Avatar
dewjr
2005 Ford Expedition Eddie Baur with dual control. Are there more than one actuator in the dash for driver/passenger?
Old Jan 18, 2018 | 10:08 PM
alloro's Avatar
alloro
There is an upper and a lower blend door.
Old Jan 19, 2018 | 02:51 PM
Skauber's Avatar
Skauber
Known problem. There's two different actuators, one for temperature, one for diverting air to roof or floor. And of course, they're different so need to know which one is bad before you buy. Or you can do as me, buy the cheapest one and rob the internal gears and put them in the original one. They'll break eventually again anyway..
Old Feb 22, 2018 | 01:11 PM
doc4bax's Avatar
doc4bax
There are two doors that use the SAME actuator in the dash. Skauber must think your are talking about the REAR air.
Old Aug 10, 2018 | 12:17 PM
dalesatter's Avatar
dalesatter
Replacement gear now available
Now you can buy just the gear you need on Amazon or eBay for just $19 or $20 with a lifetime guarantee! Wow, finally a reasonable solution now that I am on my 3rd Navigator. Just Google search the following:
Blend Door Actuator Gear Rebuild Kit (Fits Ford Lincoln Mercury 1990-2012)
Amazon Amazon
https://www.ebay.com/sch/i.html?_nkw...+actuator+gear
l plan to install the replacement gear today. I will follow up at some point, but from the reviews I read prior to purchase, they all look 5 star, my hopes are high.
It's Sold by Blenddoor
Old Aug 13, 2018 | 09:30 AM
alloro's Avatar
alloro
For 20 bucks I'd rather buy a new actuator and have the whole thing be new and not have to take mine apart.
Old Aug 13, 2018 | 03:09 PM
dalesatter's Avatar
dalesatter
Its just another option I had not seen mentioned on this forum before.
For $20 bucks, its a flip of the coin either way, only time will tell, if you can actually get the assembly delivered for $20. If "'You get what you pay for" comes into play, I would rather go with a part made of the strongest resin, as so claimed by the manufacturer, whether it's true or not I don't know, then the cheapest assembly available on planet earth. By taking the manufacturers word and virtual 5 star reviews, and considering how easy it is to open up the actuator and slide in the new gear versus having to remove the actuator and replace the unit again down the road, personally I would rather install the higher quality gear now one time and never mess with it again, at least that's the plan, especially when we're talking about the same $20 bucks.
Frankly, as this is my 3rd Navigator, I'm tired of doing this same job over and over because the OEM is crap.
Old Aug 14, 2018 | 08:29 AM
2trux's Avatar
2trux
The problem I ran into when changing the bad rear actuators in my Explorer (yeah I know it's not an Expy) was it had 2 plastic gears inside and both were trashed. The gear replacement was $20 for one of the gears, the other was not available. I bought new complete actuators for $16 apiece. Only time will tell how long they will last.
Old Aug 14, 2018 | 01:59 PM
dalesatter's Avatar
dalesatter
$16 is hard to argue with. I have read so many posts I don't know where I saw it, but one had what I thought was really good advice...when you set the temp or air blend, don't turn it all the way to maximum, back it off maximum a little so as to relieve the constant pressure from the little servo motor that is applied to the gear set.
doc4bax
Feb 8, 2018 01:06 PM
jdvern
2004 - 2008 F150
Oct 23, 2008 06:04 AM
tex599
Jun 7, 2004 03:19 PM
imsorope
1983 - 2012 Ranger & B-Series
Oct 11, 2003 10:23 PM
