Testing HPOP
Old Jan 15, 2018 | 05:06 PM
Racecar_Dave's Avatar
Racecar_Dave
Trailering
Testing HPOP
I have an internal oil leak and ive re oringed my injectors and changed my oil. i only get 200 psi at the icp after the truck has warmed up. i was wanting to know how i can check to see if my HPOP is causing the problem
Old Jan 15, 2018 | 05:41 PM
Dan V's Avatar
Dan V
You should pose that question in the Diesel forum.
Old Jan 15, 2018 | 06:06 PM
Racecar_Dave
Trailering
It says i am in the diesel forum
Old Jan 15, 2018 | 09:13 PM
Evan_P's Avatar
Evan_P
What year and engine?
Old Jan 16, 2018 | 12:51 AM
azking_Ranch's Avatar
azking_Ranch
I don't think the 6.7 has an HPOP (High Pressure Oil Pump) older diesel do.
Old Jan 16, 2018 | 07:35 AM
Tom's Avatar
Tom
The OP's profile shows that he's working on an '01, so I'm moving this one to the 7.3L forum.
Old Jan 16, 2018 | 08:28 AM
Chevota_72's Avatar
Chevota_72
If you are indeed working on a 7.3 you can deadhead the pump with gauges in each line but first you need to make sure you have a good working IPR and associated wiring for the IPR. My bet would be on an injector, injector o-ring or IPR issue. Does the truck start and run until it gets hot? Have you pressured up the HPO rails with air to check for injector related issues?
Old Jan 16, 2018 | 10:12 AM
Racecar_Dave
Trailering
what size gauge threads into the pumps lines? 1/4"?
on the IPR note my ipr runs at 8-12% duty at idle and 50%, maxing out at 64%, when the truck wont build enough pressure for the injectors. I have not replaced the IPR or its pigtail but my understanding was that is was working normally.
I have found a broken o ring and have re oringed all 8 injectors and the truck idled much better but wouldnt restart once hot.
the truck sees 1500psi at the icp when cold and will run until it shuts off. truck will not restart until oil temperature has cooled to around 100* Im running motorcraft 15w40
i have not pressureized the oil rails, what is the procedure and what should i be looking for?
Old Jan 16, 2018 | 10:39 AM
ILBCNUL8R's Avatar
ILBCNUL8R
See the "Cody Test" in this link
Ispahani3
6.4L Power Stroke Diesel
Jan 20, 2018 09:23 AM
DND58
Oct 5, 2012 09:52 PM
Gagew90
Jan 6, 2010 08:51 PM
SRUPP
Apr 26, 2003 11:24 PM
