2017 tire clearance
Old Jan 15, 2018 | 11:28 AM
Jsfleming58's Avatar
Jsfleming58
2017 tire clearance
I know this subject has been beat to death but I wanna be sure before I spend the money. I have a 17 f250 with the heavy work package (slightly higher in front). The wheel and tire combo I'm looking at is a 20x12 wheel with -52 offset and a 35/12.50 tire. Would this clear with minor trimming? Also how far will this stick out?
Thanks!
Old Jan 15, 2018 | 02:27 PM
BlueCollarPilot's Avatar
BlueCollarPilot
They are going to stick out quite a bit. I have 35/12.50/20 on 20x10 wheels, with a -24mm offset. Backspacing is 4.5 I think. Mine stick out 2.5 to 3 inches, which is further than I'd like. I occasionally hear a light rub when turning in reverse on uneven ground.
The combo you posted will definitely stick out more than that, and will certainly require trimming at a minimum I would think.
347Flatty
Jan 22, 2021 10:42 PM
tractorboy924
2009 - 2014 F150
Oct 28, 2018 09:12 AM
Cody20
1997 - 2003 F150
May 29, 2012 12:18 PM
Negrey
Jun 25, 2010 07:40 PM
jayboe
1966 - 1977 Early Broncos
Sep 12, 2006 09:51 PM
