lower steering shaft
Old Jan 14, 2018 | 06:24 PM
waine5's Avatar
waine5
Question lower steering shaft
Found a you tube video from JEG's Garage thought I'd pass it on. I'm still working on the slop in my steering and was looking into a possible issue with the rag joint and stumbled upon this possible solution. Lower steering column from a mid 90s Jeep. (no rag) Only a small modification of notching the shaft where it comes into the Double D. It doesn't have the thru bolt. Can anyone chime in if they have any pros or cons to this possibility.
Old Jan 14, 2018 | 07:16 PM
FuzzFace2's Avatar
FuzzFace2
Do you have a link to the video?
Just bolt thru the shaft is not safe if not from the factory.
That double D shaft is meant to shorten in a crash so the wheel is not pushed up into the driver.
IIRC at the top od that DD shaft is a Ujoint type deal that I hear gets play in it over time could the play be there?
Dave ----
Old Jan 14, 2018 | 07:18 PM
waine5's Avatar
waine5
Steering Shaft Upgrade - 82-92 F-body - Astro Van Shaft Modifications
How to make a Jeep Cherokee (XJ) steering shaft work in a Thirdgen F-Body
Old Jan 14, 2018 | 07:20 PM
waine5's Avatar
waine5
I'm not tech savvy; no idea how to get the link but these are the titles.
I understand what you're saying and it does not take away that safety feature.
Old Jan 15, 2018 | 09:04 AM
Franklin2's Avatar
Franklin2
There's the link. He is putting a steering shaft from a jeep into a Camaro. Not sure what that has to do with a Ford pickup. I will say if you get rid of the rag joint, you will probably get a hissing noise in the steering wheel when you turn it. That is what the rag joint is for, to get rid of the hydraulic noise from coming up the steering shaft from the steering box.
I will also say if you mess around with the double d part of the shaft be careful, there is a leaf spring in there that takes the play out of the double d. In the video he is heating and trying to get the shaft apart because of all that "glue". That is probably in there also take out any play in the double portion of the shaft. If it slides up and down good, then it probably has a small amount of play that will be noticeable a you are turning the steering wheel.
Old Jan 15, 2018 | 12:11 PM
waine5's Avatar
waine5
tks. back to changing the rag joint.
Old Jan 16, 2018 | 01:44 PM
cadunkle's Avatar
cadunkle
No need to reinvent the wheel. You can make your own with parts from any of the steering shaft component companies or just buy the ready to bolt on part off the shelf.
Standard steering shaft: https://www.summitracing.com/parts/brg-000980
Fancy luxurious steering shaft: https://www.summitracing.com/parts/brg-000985
Note there can also be significant slop in the column itself, primarily from a cracked lower bearing retainer. It may be worth replacing upper and lower bearings and the retainer if needed in your column.
yasky69
Modular V10 (6.8l)
Aug 22, 2010 11:35 AM
tastyklair
Jan 4, 2007 09:56 PM
eduardo
1978 - 1996 Big Bronco
Oct 11, 2005 12:05 AM
Snowman671
Aug 19, 2005 01:26 PM
jbulson
Oct 13, 2004 01:12 AM
